Question about Electrical Supplies
I am rebuilding the armature of a 5kva 220 380 volts 50hz generator but I could not take the coil connections couse they were very damaged. So please if anyone could help me with this.
    New Friend:
  • 35 Answers
SOURCE:
  • 3 Answers
SOURCE: Generator Armature Removal Honda EMS 4500
Sorry, I don;t have a solution but do you have a good coil from one of those you would like to sell?
Posted on Dec 24, 2008
protek480
  • 1730 Answers
SOURCE: HONDA GENERATOR PROBLEM
The armature (rotating field) is powered by the voltage regulator for 'excitation' which is the term describing a magnetic, revolving field. This magnetic field 'induces' voltage into the stator windings (stationary outer winding), producing voltage for use at the recepticles. Some older generators used a 'permanent magnet field, instead of using a powered winding from a regulator and the voltage and frequency were set by the RPM.
Frequency is still a function of RPM, but the voltage is controlled by the voltage regulator.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Aug 29, 2009
  • 141 Answers
SOURCE: we have a couple of brutes that hit slow, I've
Sounds like you have too much suction in the hammer cylinder. The hammer may be getting stuck at the top of the cylinder. Inspect to see if the hammer beat piece will slide out of the hammer cylinder. There may be too much grease behind the hammer causing suction at the up stroke. There may also be scarring inside, so inspect to see if the hammer beat piece slides smoothly. Hope this helps.
Posted on Sep 14, 2009
sal_kh_sab
  • 98 Answers
SOURCE: KIPOR KDE 6700TA 5KVA Generator
forget about the display read the manual and find out how many volts are needed to charge the battery....then
get a voltometer and disconnect the terminals from the battery and connect them to the voltometer while the generator is running...
find out what the reading is...if the reading is zero (0)...then post a problem on (no out put)...
if not.....then there has to be a mistake...
if it reads a voltage thats too low..then you AVR card is burnt out (AVR card is located in the other end of the generator (beyond the stator-side cover)...
Posted on Oct 25, 2009
Testimonial: "Khan sb. truly is a professional. "
  • 5 Answers
SOURCE: pull armature on generator from engine
Put the armature thru bolt in and back off about two turns. Smack the thru bolt hard with a hammer and the armature will release from the tapered crankshaft. You may damage the thru bolt. If so either get a new one or use a piece of all thread and a nut.
Posted on Apr 13, 2010
How to increase the output voltage
Measure the Generator after 10 minutes the first measure but not only to one power outlet with doing a measure with a multimeter its not done so because the generator is fully unloaded then you will see 105 vac
Measure on one outlet and use a paint stipper a 2000 watt type and measure at the same time on the second power outlet with a multimeter on AC you should get more volts out to measure instead of 105 volts then you hear that its generate power and blow more smoke you will be seen a 115 or 120 volts if you increase this generator its possible you get if you are increase the idle power to 120 volt can create an over loading of 200 volt or more over the outlets that can give damage if it the stator electric field generate power outside its level it can blow up your expensive tools and in a short time you think there is not enough power on my tools anymore then your armatures are become bad and the tools are hot in a short time warmt dissipation has blow up armature and nothing smels hot but the tools are blowing up. and you see nothing inside because the tools will not are getting black burned and hot but the to high magnetic pulse burns the weak points inside the armature in a fraction of time.
Beware of that the adjusting is normally doing with a tacho meter and a suggestion of about 3000rpm and not more of the stator what its max depend on model . but adjust by the load power of a working paint stripper it can have enough if you adjust 120 volt by load.
Mar 06, 2016 | Electrical Supplies
DO I HAVE TO PULL THE GENERATOR OFF A LINCLON 300D TO REPLACE THE REAR MAIN SEAL?
Yes, You will have dis mantle the front of the machine, The front control panel will have to be removed, the fuel tank will have to be removed,the exciter rotor and stator will have to be pulled, the field will will have to be removed before you can remove the main armature, which has to be decoupled, then the starter will have to be pulled, the mounting baser plate will have to be removed, which will give you access to the rear main seal, whose replacement will take about 1 minute to remove and 1 minute to install, then all that has been removed will have to be installed,check the main generator field to make sure there is no oil or oil impregnated dirt on the inside covering the pole pieces or the shunts and series coils, if there is, use a pressure washer to remove it, do not use excessive pressure or solvents or harsh soaps, keep the water stream a respectable distance from the coils so as not to damage the insulation, let the generator dry on a flat surface, in ambient temperature for a few days before reassembly take care to mark the conductors in the CV unit before you remove it, mark all conductors before you disconnect any of them Take the time to study the welder before you attempt taking it apart. The Generator is very heavy, and will swing down and be damaged if you have not balanced it with a strap before removing it. The main armature must also be balanced and decoupled taking the flex plate with it when it is removed, take special care not to damage the commutator bars when moving the armature around, best storage for the armature is standing up, flat on the concrete floor of your shop I forgot to mention that the exciter armature is held onto the main armature shaft with a tapered flange, keyed washer and a 1-1/8" nut that should be removed with an air wrench to prevent any damage to the armature shaft by the use of hammers or pipe wrenches. Damage to these machines is non forgiving, and will require purchase of new parts if caution is not exercised
Oct 02, 2014 | Lincoln Electric Classic 300D...
Polorized generator as per manual. went from no output to .2-.4 amps. do I need to rebuild the generator?
Hi, I own a 1976 XLCH1000 and had a similar problem some years ago.
The dynamo must be energized correctly as if not it wouldn't work.
Disconnect the two wire on the dynamo.
Connect a volt meter from the armature connection to the bike frame, negative.
Start the bike up and on a fast tickover there should be 2 to 5 volts present. Momentarily connect, while still monitoring the voltage, a wire link from the field connection to the bikes frame (earth or negative of the battery). The voltage should shoot up to about 25 to 30 volts. If it does you have a good dynamo. If the dynamo is flashed the wrong way around then a negative voltage instead of a possitive voltage will be produced and damage the regulator if it is the electronic type, like on mine.
If the voltage is low, change the brushes and clean the commutator with some wet and dry paper scraping out between the segments to clear the dead carbon deposits. Don't forget the end bearings are "Oilite Bearings" Don't use grease a drop of 20-50 is fine.
Anywhere else in the world, we put voltage on to the field terminal to produce current at the armature, trust the Americans to be different!
Ride safe and loud pipes save lives!
Hope this solves your problem.
Nov 09, 2010 | 1979 Harley Davidson XLH 1000 Sportster
Pull armature on generator from engine
Apr 10, 2010 | Coleman Powermate Premium Plus 6250W...
Coleman generator not putting out enough volts
What can happen with these generators is there is a shield built into them to devert the heat that is produced but it is still released into the surrounding components and causes a plastic rain guard to melt slightly around the edges and the melted plastic fuses to the armature and causes voltage drop through the brushes due to lack of contact. It is a relatively simple fix but it requires a rebuild kit that can be purchased aftermarket through your local generator dealer. It provides instructions for the rebuild but are often times confusing and it is usually cheaper in the long run and less hassel to let the dealer install the rebuild kit for you. If you do decide to attempt this yourself there is an 800 number provided where it can be registered and it will allow you to access schematics online for this rebuild. Hope this helps, good luck!
Sep 01, 2009 | Coleman Powermate Premium Plus 6250W...
HONDA GENERATOR PROBLEM : SEPARATE MOTOR AND GENERATOR CONNECTED BY V BELT. MOTOR HAS TWO MODULES UNDER FLYWHEEL. ONE LOOKS LIKE ARMATURE THAT POSSIBLY SUPPLIES PRIMARY CURRENT TO THE HIGH VOLTAGE COIL---...
Aug 28, 2009 | Electrical Supplies
Aug 04, 2009 | Kitchen Appliances - Others
Armature is turning much slower than blot connected to shaft on motor of an E1-100-D Generator.
DO NOT turn the gen. on any more...you might damage the crank or worse..
hold the crank still by pulling the starting handle and tightening it to one of the red bars(the point of this is to restrict crank movement...you can try anything as long as the crank stays still) then rotate the armature (you might need to dislocate the stator for that purpose).if it got rotated then your crank is fine...and the problem is either with the screw that holds the armature or the armature's screw hole.
that is if the armature rotated easily...if you felt or heard weird things while spinning...then am afraid something inside the engine is damaged..but if the engine is running fine then the last idea mostlikely is not whats wrong.
Jun 07, 2009 | Briggs & Stratton Power Products 5,550...
Nov 27, 2008 | Kitchen Appliances - Others
Electrical Supplies Logo
57 people viewed this question
Top Electrical Supplies Experts
Gene Haynes
john h
Are you an Electrical Supply Expert? Answer questions, earn points and help others
