I need a complete guide on how to replace theses parts.
SOURCE: NEED TO REPLACE BLOWER RESISITOR. FAN ONLY WORKS ON HIGH SPEED
Under the dashboard on the passenger side you will see the blower motor. Near the blower motor inside the air duct is the resistor. It should be held in place by two screws. Hope this helps. Good luck
SOURCE: replace low beam headlight on 2003 chevy trailblazer
I just replaced the low-beam bulb on my 2003 Chevy Trailblazer. The grill just needs to be loosed slightly. Then, raise two L shaped brackets, one on each side. For the inside one, I needed to use a flathead screwdriver to get to it. The light assembly can then be pulled out. Remove the rubber cover and rotate the bulb one quarter turn left to release it. Pull out the bulb, replace with a new one ($11.50) from Advance Auto Parts, and reverse the process. Once I figured it out, took about 10 minutes total.
SOURCE: How do I replace the fuel filter in my 2004 Chevy
The filter is on the inner frame rail in front of the
gas tank on the DRIVER'S side.
You undo the rubber clip that holds the filter and pull the whole thing
down so you can undo the clips for the input and output. Be careful to
not mix these up. If you do, just follow the lines and see which way
they go.
Don't release the fuel pressure (valve is inside the screw off cap)
until
you have pulled the filter down off of the frame, and have something
ready
to catch the small amount of gas that will come out.
SOURCE: 2004 chevy trailblazer fuse box diagrams
I have front and rear a/c. The air is blowing in the back but not in the front. Don I have 2 blowers/units. Could this be a fuse?
