Heating & Cooling Logo
James Hinkle Posted on Mar 03, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Carrier infinity 96% Burners come on burn a few seconds then make a noise shutoff amber light blinks 3 times yellow or amber burners never come back on
jerry fitz
Level 1:
New Friend:
  • Contributor 30 Answers
  • Posted on Apr 02, 2019
jerry fitz
Contributor
Level 1:
New Friend:
Answers
30
Questions
0
Helped
30258
Points
56
Its either a flame sensor or you are tripping limit or the false sensor is sensing flames are rolling back instead of going into your secondary heat exchanger. If thats the case you should contact your local HVAC shop luckily you have a carrier furnace and heat exchangers are under full lifetime warranty because of a design flaw. Otherwise youd he looking at a hefty bill
protojexxx
Level 2:
New Friend:
  • Expert 61 Answers
  • Posted on Mar 03, 2019
protojexxx
Expert
Level 2:
New Friend:
Answers
61
Questions
0
Helped
20801
Points
115
Locate and clean the Flame sensor with emory cloth or brand new dollar bill. You will be good to go. Do not use sand paper or harsh abrasives!
5 Related Answers
Anonymous
  • Posted on Jan 03, 2008
SOURCE: Blinking oven and heating Lights
for no reason the cleaning light went on, even though the oven was not on. The oven light and heating light were alternating each blinking 5 times. The door locked up, too. It seemed to think it was in a cleaning cycle. Any way, problem solved by throwing off the main breaker and all is working fine since... except now, for no reason the oven fan, not the exhaust fan, stays on all the time!
Anonymous
  • Posted on Aug 18, 2008
SOURCE: Clicking noise on cooktop even when all burners ignite
I have a viking gas cooktop. The ignitor on one of my front burners wouldn't stop clicking even after the flame ignited. I swapped that ignitor with the ignitor from a back burner, expecting that the problem was with the ignitor and that the back burner would start to click incessantly, but at least I'd have my favorite front burner for use. Instead, the front burner was then only clicking 50% of the time and the back burner was fine, suggesting the problem was related to the burner not the ignitor. I pulled the front ignitor a bit away from the burner and now it is working normally. Hope this helps.
Anonymous
  • Posted on Nov 10, 2008
SOURCE: burners with yellow tipped flames
I have a G.E. natural gas cook top. All 4 burners have a lot of yellow flame all of a sudden. Is there an adjustment for this I could make? Please explain the best you can.
Anonymous
  • Posted on Jan 11, 2010
SOURCE: Furnace comes on for 1 min then kicks off, repeats this cycle
MY FURNACE WOULD RUN FOR ABOUT TWO MINUTES , THEN THE BURNER WOULD GO OUT BUT THE BLOWER WOULD CONTINUE TO RUN , LONG ENOUGH TO COOL THE FAN LIMIT SWITCH DOWN , THEN IT WOULD START THE PROCESS ALL OVER. WHAT FIXED MY PROBLEM WAS THE SECONDARY HEAT EXCHANGER THAT IS LOCATED JUST ABOVE MY BLOWER MOTOR WAS PLUGGED WITH DIRT , WHICH RESTRICTED THE AIR FLOW , CAUSING THE FAN LIMIT SWITCH TO REACH 200 DEGREES AND SHUT THE BURNER DOWN . YOU'LL HAVE TO TAKE THE BLOWER MOTOR OUT TO GET TO IT , BUT MY FURNACE IS RUNNING PERFECT NOW
kingbrizzle
Brandon Berry
  • 407 Answers
  • Posted on Feb 03, 2010
SOURCE: I have a Carrier Infinity 96 gas furnace with no heat
That means that the furnace is throwing a code to trouble shoot whats wrong. Most of the time, furnaces will have a code list on the inside of the door cover to explain what each code means, some of them don't. Its hard to say what it could be without knowing where to start. However, answering a few questions with someone knowledgeable over the phone if possible could help speed things up, but it would involve you being at the furnace and seeing what happens before it throws the code. If you do have a code list, this would help tremendously.
Testimonial: "Great Solution. I spoke with the installer of the unit this morning and went through everyting you mentioned. It was as simple as a loose connection."
SOOT PROBLEM CAUSED BY YELLOW FLAME
If they burn yellow then they are blocked IE lack of air causing flame to burn floopy yellow hence soot , clean burners and orfices to burners .
Mar 25, 2012 • Grilling
3helpful
3helpful
2answers
Flame sensor dirty
Sandpaper lightly scrubbed over the sensor tip to remove any contamination.
Sometimes cleaning is not enough and the sensor must be replaced.
Gas Grill Burners with yellow flames coming from beneath them
the flames should be blue and the burners clean. check gas pressure and the air mixture dampers. touch air will give you the same effect. if the burners are clean, it is the mixture. as far as the slots in the bottom. i have not seen that. but i work on commercial ranges.
Gas heater won't work
Which flame sensor did he replace? The pilot flame or the plenum temp. sensor.
Khypermedia DVD RW - not being consistent
Try to re-install the drivers for the drive.
Hope this helps!
Pioneer DVD Burner Drawer will not open
hi rscarboro
on the left side of the dvd drive there is a small little hole which you can insert a paper clip etc to open the draw
push it in this will open the draw for you.
riz.
15helpful
5answers
Panasonic PT-50LC13 Power Light Blinking Yellow
My Panasonic PT-50LC13 when turned on has a green light for a few seconds you can hear the fans turn on and then you have a yellow/amber light that starts to blink 8 times i have replaced the bulb and the door is closed any ideas?
8helpful
3answers
Burners with yellow tipped flames
Top Carrier Heating & Cooling Experts
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
