SOURCE: TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
SOURCE: Half Screen has colored lines, Half screen is working ok
there is a defected capacitor in the vertical circuit trouble shoot and replace. or if the vertical circuit is separate then replace the whole board.good luck
SOURCE: TV Keeps flashing Fuzzy black and white static then the picture appears
The half picture is a verticale problem. This is difficult to repair. Send to a repair shop.
SOURCE: Plasma "warm up" is now up to 30 minutes and climbing
put a towel across the top of the tv so it can heat up faster and you will get your picture. be carefull!!
