Question about Amana Dishwashers
Amana Dishwasher ADB3500AWW door will not open when cycle is finished.
  • Amana Master
  • 1,594 Answers
SOURCE:
markevans
  • 148 Answers
SOURCE: Kenmore dishwasher locks. after cycle, can't open door
bad solenoid or controller
Posted on Dec 21, 2007
e-Guru
  • 3917 Answers
SOURCE: Amana Dishwasher Mod. ADB1500AWQ, Door won't open.
HI,
Please check whether the plastic pins are broken.
I removed the inner door panel and found the handle broken. It has integrally molded plastic pins that provide a pivot for the handle to push against the release assembly. These were broken off. Also noticed that there were some small fingers molded on the back of the switch panel that were snapped off. I'm not sure what these are for and I can't see how they are needed for the latch operation. My hunch is that they aid in positioning the handle during factory assembly. I'm NOT going to buy a new switch panel to replace these!
I don't know why the handle broke but it did so in stages. I think one pin broke, and then everything else broke because of added misalignment and stress. The good news: a new handle only costs about $10 and I'll have it in a couple of days. Thanks
Posted on Apr 24, 2009
mmoorree
SOURCE: KitchenAid Dishwasher Door Pops open during cycle
The problem seems to be the loosening of the screws that hold the interior stainless steel skin to the door frame--not the latch.
With the door in the open position you should find a total of twelve screws (5 on each side and 2 on top at each side of the latch). The screws have a particular type of head which may require a trip to the hardware (its a $1,000 dishwasher take the time to get the right screwdriver). They are called TORX screws the size on my dishwasher was a T 15. These type of screw heads were designed to fit automated torque drivers at the factory that set the screws to the proper tension. So some care should be given when you retighten them. Turn until the screw is snug and there no movement of the inner door skin but don't over tighten. Giving it that extra 1/4 turn can be enough to strip the screw out and create a bigger problem.
Yes--you shouldn't have to be doing this to a KitchenAid appliance that cost this much--but I suspect that this will become a feature of periodic maintenance. The heating and cooling generates enough movement that overtime these screws work themselves out. My wife who was the once to make the right diagnosis noticed that the screws at the bottom were almost entirely out.
Posted on May 07, 2009
  • 677 Answers
SOURCE: dishwasher rinse water is soapy
the problem is hard water. www.dishwasherfilter.com has a new product out that solves this problem once and for all. it filters the water going into the dishwasher removing the hard minerals that leave those spots. it is very affordable and guaranteed to work or your money back. you will love the way your dishes look.
Posted on Aug 22, 2009
SOURCE: Amana Dishwasher door will not open. Latch you grap is very loose
We have the same problem and I bought the latch locally for $26.00 now trying to figure out exactly how to get the door apart to replace.
Posted on Mar 04, 2010
Dishlex DX203SX Dishwasher door wont close
check the lock maybe it flipped shut lock maybe getting stiff from steam?
Feb 07, 2015 | Dishwashers
you did not giver manufacturer, model and year, it is not possible therefore to give detailed info what to do - for future references - do provide these "little" details, telepathy is overrated and usually do not work...
from your description can be several causes of that, one of them is motherboard fault, another will be actuator and third can be mechanical fault within lock or with hinge... make your pick...
Door will no unlatch after wash
Make sure the machine is completely finished with all cycles that it was commanded to perform. Your machine may have safety system that wont let you open the door while is in HOT conditions. This should be in your users manual(guide). Good luck, best regards.
Feb 02, 2011 | Amana 24 in. ADB1500AWS Stainless Steel...
Have a brand new maytag dishwasher. When the cycle is finished the clean light stays on and I have to push buttons to clear is this normal?
If you open the door after the cycle, does it clear the display? Mine is a different maytag model, and when it's done it shows the display as clean. The display will go blank when I open the door manually... let me know if that helps.
KEN
May 10, 2009 | Maytag 24 in. MDB5651A Built-in Dishwasher
My ADB1500AW Amana dishwasher is leaking at the water fill sensor
i have adb1500 i have replaced all the board on front of door, and it leaks at the bottom of door.
May 02, 2009 | Amana 24 in. ADB1500AW Built-in Dishwasher
Dec 12, 2008 | Amana 24 in. ADB1500AW Built-in Dishwasher
Bosch dishwasher not 'steaming' plates dry
first check to make sure you don't have a air dry option.then look at the thermostat then heater.
Oct 01, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Kitchen Aid Superba Wisper Quite will not start cycle
Intermittent door switch, should be available, easy to change out and inexpensive.
Aug 04, 2008 | Dishwashers
Soap doew not disolve
first start the washer listen for it to fill then open the door and see how much water is in it let me know but hold my rating till we finish
Jan 31, 2008 | GE 24 in. GSD3210Z Built-in Dishwasher
Dishwashers Logo
37 people viewed this question
Top Amana Dishwashers Experts
Steve Allison
Steve Allison
Jose Pino
Mike
Are you an Amana Dishwasher Expert? Answer questions, earn points and help others
