SOURCE: Could Anyone Tell Me, How To Unlock Region Free A BDP-S300 Player??
http://www.stegen.com/product_info.php/products_id/1019?osCsid=daccaf0338a597dd1985e0ad70ac277a
SOURCE: Code for a Sony BDP-300 Blu-Ray player
Try 21516. Code given to my by phone by Bose costumer service.
SOURCE: unlock sony blu-ray bdp-s370 player
Turn on the BD player. Press and hold the PLAY button and the STOP button until UNLOCKED appears on the front panel display.
SOURCE: How to change region code
Hello
You can set your BDP-S570 region free in case of playing DVD discs from all regions. But making region free to Blu-Ray discs is yet to come. To make it region free, you must have a special remote mentioned below. With its original remote, this cannot be done. All the proceedings are given.
To make BDP-S570 Region Free for DVD play.
This hack is the same as for the S370, 360, and S550
and uses the "One For All Kameleon 6 " or URC-7950 remote
[Please note the remote control model need to make it region free]
At first, the remote must be programmed to make the DVD region free. Do the following to make it programmed. There are 32 steps for this.
1. Press and hold the [Magic Hat] button until the rabbit appears (the IR indicator bars also flash twice)
The Rabbit in the Magic Hat should be visible for all the following steps.
Pausing too long will cause the Rabbit to dissappear.
If it dissappears then repeat step 1 and also the block of instructions you were doing at the time.
2. Press [DEV SET]
3. Press [DVD]
4. Press 0533
5. Press [OK] - The IR indicator bars flash twice
6. Press [ESC]
7. Press [KEY MAGIC]
8. Press [DVD]
9. Press (but don't hold) the [Magic Hat] button
10. Press 00189
11. Press 1 (The IR indicator bars flash twice)
12. Press [KEY MAGIC]
13. Press [DVD]
14. Press (but don't hold) the [Magic Hat] button
15. Press 00255
16. Press 2 (The IR indicator bars flash twice)
17. Press [KEY MAGIC]
18. Press [DVD]
19. Press (but don't hold) the [Magic Hat] button
20. Press 00095
21. Press 3 (The IR indicator bars flash twice)
22. Press [KEY MAGIC]
23. Press [DVD]
24. Press (but don't hold) the [Magic Hat] button
25. Press 00221
26. Press 4 (The IR indicator bars flash twice)
27. Press [KEY MAGIC]
28. Press [DVD]
29. Press (but don't hold) the [Magic Hat] button
30. Press 00079
31. Press 5 (The IR indicator bars flash twice)
32. Press [ESC]
The remote is now programmed and ready to use, to make the BDP-S570 region free:
Then Comes the region free setting procedure
1. Use the remote that came with the player to bring the player out of standby, make sure there isn't a disc in it. It should read "HOME" on the front panel.
2. Press 1, 2, 3, 4, 5 on the oneforall remote. The blue 24p light will start flashing on the front panel
3. Put the player back into standby with the Sony remote
4. Next time you turn on the player it will be region free for DVD playback
OK.
SOURCE: Do you know a region code crack for Sony BDP-S360
Hi there, please get the code here : www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
www.dvdreviewer.co.uk/Forums/...region_code/page1
Best Regards, Jay_3e4r5
