SOURCE: There is no suction to the floor sweeper. The
Sounds like you have two separate problems here. If the brush bar does not rotate, probably the belt is broken. This is easily replaced, but you need to be precise about which model you've got so you get the right belt.
Loss of suction is due either to a blockage or, quite often, to a split in the short length of clear plastic hose that leads back from the brush bar enclosure. Repair is possible but replacement is better.
If you need more help, post here again.
SOURCE: Sweeper Brush doesn't turn.
Could be that too much hair, string, or long fibers have been collecting around the roller. Remove it and clean it off. Also check the duct behind roller that goes up into the connection hose. Ther most likely is some sort of blockage.
SOURCE: Can I buy replacement batteries for Shark Cordless Sweeper
I need a replacement battery for my Shark Stick sweeper model V1911 N. Can't find it on their web site. I guess it is old. Murnieruth
SOURCE: My shark bagless sweeper worked
This will probably cost you more to repair than to buy a new one. Does it turn on at all?
SOURCE: brush does not turn.
these stick mmachines do not have a tremendous amout of suction at the best of times but if it has a full bag, or full dirt container, or dirty exhaust fiters it will take away from the air flow as well. take a flashlight and look up in to the tube of the floor attachment to see if you can see something blocking the tube.If there is no obstructions it may have a roller bar that spins on the bottom , so turn it over and turn it on and if it has a roller bar and it is not spinning it probably needs abelt . If there is no roller bar and no blo0ckage chances are it is just weak at the floor tool as the air a further to travel all the way up from the floor so it takes away from the air flow again. good luck.
