SOURCE: How do I get assembly instructions for Wildon Home Corvallis Trimline Full Size Futon Frame?
You can contact factory direct or place you purchased from. Contact Us: 877-WAYFAIR (877-929-3247). I know the item is from Vietnam and instructions are not the best.i would lay out all your screws by size. Connect your back board to both end pieces withe the medium size screws. Then mount front board with long screws should be 4 for each side. Then assemble the couch lay down parts place on your assembled base. Uses washers on the long screws as this section swivels up and down. This reduces friction between the wooden parts. I hope this helps. Send your photos to mddoc13atyahhoodotcom. I will try to quite you. Attention Bob
SOURCE: instruction manual for Mainstays Silver
I wonder why this is in the kitchen stove section? Walmart.com or stores have the manual. Pavanip's question as answer could be a bent frame or uneven floor.
SOURCE: I have this futon, Im in need of new legs, miss placed in moving.
Did you try contacting the original manufacturer to see if legs are available? If nada, maybe a furniture store can help you out.
Mattresses:
Mattress Size
Width
(short side)
Length
(long side)
Twin
36-41
72-76
Full
52-55
72-76
Queen
58-62
78-82
futons:
Twin
39x75 inches
Full
54x75 inches
Queen
60x80 inches
