SOURCE: code for polaroid tv
I just got a new directv receiver...dvr....the codes for polaroid were not listed on the unit but were included in the booklet that came with it. They are as follows....10765,10865,11262,11276,11314,11316,
11326,11327,11328,11341,11498,11523,11991,11992
These were all listed for Polaroid. Hope this helps.
SOURCE: My Polaroid TV model not listed, it's TLX-04240B
I got the 42" Polaroid HDTV from Walmart (on Black Friday) and was able to link it to my Tivo remote using the Mitsubishi setting and code 0001.
1. Tivo Central
2. Settings
3. Remote Control
4. Part 1 and then Part 3
I use it to Power On/Off and Volume control.
SOURCE: Directv remote code for polaroid tv
Slide top button on remote to tv. Press and hold mute and select button until the green light on the remote blinks twice. Then press 991. Then press 1. Then press the tv power button once. If the tv doesn't respond hit the channel up button on the remote. If that works press select to store the code and slide the switch back to the left. If it doesn't work keep hitting channel up until it does. It can take up to 30 minutes but it works.
SOURCE: POLAROID 1511-TLXB LCD TV Remote Code for Verizon FiOS STB
I posted that as a point of information. I noted from searches that other people were having remote code problems w/that TV set. Code 0205 worked for me.
0019 = NEC1, device code 4
0054 = RC-5, device codes 0 and 3
0150 = Mits, device code 71
0178 = NEC1, device code 4
0765 = NEC1, device code 64
1256 = NEC1, device code 64
1276 = $0057, device code 71
