The most likely cause is that you have a bad temperature sensor. Some wine coolers will display the set temperature, not actual temperature so although you set it for 58°, the temperature inside is much colder. If the temperature sensor is bad, then it's likely sending a signal to the control board that says it like 99° so the wine cooler is always trying to cool down to 58°. If you have an independent thermometer, put it in the wine cooler and see what it reads.
FYI, bad temperature sensor are pretty common in wine coolers. It's a design flaw that most manufacturers are just recently correcting.
SOURCE: My refigerator and freezer are not cooling enough
Is the fan in the freezer running?? Is there frost on back panel of freezer??
SOURCE: Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
SOURCE: Marvel 61WC Wine Cooler
sorry for the delay in response time you definatly have a bad thermistor, not able to stabilze temp so it contionues run never shutting doen freezing everything, who ever repairs it (if they haven already,)make sure they put all 3 new peices in, thermistor, potentiometer, and contol box. all 3 come in one kit, 20 min to install
SOURCE: Over Chilling Refridgeration set on 7C still goes to 0C Digital thermostat
behind or inside the digital display casing-mike
