SOURCE: Where can I buy remote control for Yamaha DSP-3090
You can get a remote for this unit from here: http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=DSPA3090&brand_pn=YAMAHA_DSPA3090&mode=large&uid=11819547734530
SOURCE: yamaha rx-v800 remote control's damaged
it can be accessed via the main unit controls but you need to go through your manuals. Maybe you can get your remote repaired still... maybe not badly damaged caused by corrosion.
[email protected]
SOURCE: AMPLIFIER CENTER CHANNEL NOT FUNCTIONING
Center channel will not work unless unit is set for Surround or Pro Logic. Make sure center channel's volume is up
SOURCE: Need code to enter for my remote to control a Yamaha RX450 receiver
G'day mate
What model TV, remote and amplifier do you have? I can help you with a little more info
regards
Graeme
SOURCE: I am looking for the remote control code for the
The code for a Yamaha DSP-AX-620 is 94. Hold down the on/off button on remote while you type in the code. Hope this Helps
thank you much for you help!
