SOURCE: Hard Reset
According to the manual for this Razr2 ver9
on the main menu map there are several topics
SOURCE: Verizon Westell 327w - can't get all devices going
You need to select the Reset option on the interface, so it reassign news IPs to all the 8 devices. Hope that will helps!
SOURCE: I bought a Garmin Nuvi 200 at a yard sale and it
You actually have two problems; you won't just need the pin code, but will need to know at which location the pin code was set.
The system is designed to make stolen Nuvi's useless and cannot be bypassed without internal hardware changes which will cost more than replacing the unit. Unless you can obtain the pin code AND take the Nuvi to the location it was originally entered then it's totally unusable.
Chalk it down to experience and resell yours as being for spares or repairs.
SOURCE: Can u unlock the pantech caper
If the phone is tied to a particular network all you have to do is to unlock your phone to use it any other GSM network. You can get the unlock code through online. Give your IMEI number & get the unlock code for ur mobile .............You also get through online..........I will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
SOURCE: pantech pc controle suit
There are 3 things you need to do. (1st) you need to download Pantech PC Suite from http://pantechusa.com/support/ease - Save PC Suite to "Program Files" on your computer. You need this software before you will be able to connect with your phone. If this download does not work on your computer it could be that it is not able to get past your security or firewall settings. If you still can not get it to download I would go to another computer and transfer the program for that computer to yours with a USB flash drive. (2nd) after you download this software you need to go to and open the "Program Files" folder on your computer. Then open the "Pantech" folder. Next open the "Pantech PC Suite" folder. Now open the "P2020" folder. Finally open the "USBDriver" folder. This folder should contain some that looks like PTQH_V1_1_4583_1215_SETUP Click on it and install it on your computer. This is a special driver that is required for your computer to be able to communicate with your phone. (3rd) you need to a USB data cord (this is different for a charge cord). I purchased a data/charger cord for mine. It is able to charge or transfer data/charge at the same time. It is as simple as that :C Note: After you install and run Pantech PC Suite the program will give you the option of connecting to your phone with Bluetooth. However, if you don't know it already - anytime you use Bluetooth on the Pantech Ease it will really drain you phone battery and battery life on this phone is not very good to begin with. Hope this is a helpful solution for you.
