SOURCE: microwave does not heat
What could cause this problem coud be a bad door switch, a bad HI Voltage capacitor, a bad power transformer, a bad Rectifier, a bad magnatron,or a bad circuit control board. Any one of these repairs could run from 65 to fix, all the way up to 200 bucks. You are probablt right, its time to buy a newer type with more lights, bells, and whistles. Good Luck
SOURCE: Everything works except heat
this is something you should probably call a repair technician for, due to the danger of the componentry.
Usually in ther case of this problem, even a technician will advise you to replace the unit, in the minds of cost effectiveness and safety...
SOURCE: everything appears to work fine but it is not heating anymore.
If the microwave oven appears to be working but it is not heating the food, it is very possible that the magnetron, or its power supply has failed.
Jerry G.
SOURCE: My microwave starts however food does not heat up.
Micro wave as the name suggests produces heat when the micro waves aimed at an object causes the water molecules inside the object to vibrate hence producing heat.The gadget responsible is the magnetron. If your magnetron is not receiving ht voltage or receiving but faulty, then your micro wave wont work please take precaution when opening micro wave due to high voltage caps that remain charged sometimes even when it is off.check the high voltage fuse/ diode and capacitor if they are fine and the step up trans former o.k then the only option is to replace the magnetron
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
