Hi there...
E21 - Drain flow error. This error will be displayed when the unit senses that the drain process is taking too long. This error may be caused by a blockage occurring in the coin trap or in the drain line. ... Clean out the coin trap regularly to ensure normal operation of washing machine.
Try checking if the hose is kinked, bent, or clogged. Also check drain filters. good luck
https://www.6ya.com/mrmmike
E21 Problems with water drain in wash phase
Check the drain hose and pipe for blockages.Replace the component if necessary.Good luck with the machine.Please do post comments and results.
SOURCE: i need a manual for a teka washer/dryer A ls13
We have a Teka washer/dryer A-L512 1200 and all the clothers are comming out with fluff on and the dryer takes too long to dry. We can't find the filters, where are they?
SOURCE: Please help me as whenever
Sorry but with such a fault it is virtually impossible for anybody on this forum to remotely guess what is wrong with your washer ;-0(
It could be internal wiring/plugs sockets, control panel switches, control PCB. I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Hello markramos66 - An error code E21 commonly refers to the water in your washer is not pumping out fast enough. First, check the drain hose for any restrictions or kinks. If you have check the hose and it appears to be clear and free, then potentially the underlying issue may be the main control board or pump. Generally it is a good idea to have a professional take a look at it to get to the root cause. Cost of parts and technical expertise entailed in these types of replacements can be a bit tricky.
