1525341576
is the master code of your mobile.
o What is a Master Code I Hear you Ask?Well, lets assume you have forgotten your security code. The master code is a 10
digit number that will always be accepted as if it were your actual security code.
You can use the master code to change your security code back to what ever you like. When your Nokia
handset asks you for the security code simply enter the master code.
How do you Generate the Master Code?The master code is specific to your
handset and is generated using the handset 15 digit IMEI number (
serial number). The IMEI number can usually be found on the sticker underneath the
battery or by typing *#06# into the phone keypad.
Which Nokia Models will this work for?The calculated master code will only work for DCT3 and DCT4 Nokia phones. It will not work with the newer BB5 handsets. See below for a rough compatibility guide or look at my Nokia generation list to check if your model is supported. The feedback I have received is that's IT WILL NOT WORK FOR THE 6230i model (the 6230 is fine).
Compatible phone models* DCT3 2100 3210 3310 3330 3410 402 5110 5210 5510 6110 6150 6210 6250 6500 7110 8210 8250 8850 8890 9000 9100 9210
* DCT4 1100 1101 1110 1600 2300 2600 2650 3100 3120 3200 3220 3510 3510i 3650 3660 5100 5140 6020 6021 6030 6060 6070 6080 6100 6101 6103 6170 6111 6220 6230, 6260 6310 6310i 6510 6810 6820 6822 7200 7210 7250 7250i 7260 7270 7280 7360 7600 7610 7650 7700 8310 8800 8910 8910i
Incompatible phone models* BB5 5500 Sport, 6131, 6125, 7380, 7360, 7370, E70, E61, E60, 3250, 6280, 6681, 6680, 6630, 6233, 6151, E50, 7390, 7373, 5200, 5300, 6136, 6288, N70, N71, N72, N73, N80, N91, N93,
N70 Music Edition, N95, N91 8GB, 6300, 6086, N76, N93i, N73 Music Edition, E90, 3110 classic, 6110
Navigator, E65, E61i, N80
Internet Edition, 5700, 5070, 6120 Classic, 1650, 2630, 1200, 1208, 2760, 3109 Classic, 6500 slide, 3500 classic, 6267, 6121 classic, N81 8GB, N81, N95 8GB, 7900 Prism, 7500 Prism, 6555, 5610, 5310, E51, 6301, N810, N82, 3110 Evolve, 8800 Arte, 8800 Sapphire Arte, 3120 classic, 2600 classic, N78, N96, 7900 Crystal Prism etc.
* ASIC 11 2760, 2626, 2660, 2630, 2610, 2610b, 1112b, 1112, 1110i, 1200, 1200b, 1208, 2310, 8800 Sirocco
