This is just a guess...most are located either at the bottom of the tank itself...or at the carburetor location.Or if your having to remove the tank. Some people take a pair of vise grips and just gently crimp the hose...where the fuel doesn't' leak out. "CAUTION" Any time you are working around combustibles...make sure there are no sources of ignition that might set off a fire. SAFETY RULE #1
Hi you will get the info here
http://www.mytractorforum.com/12-john-deere-forum
or here
http://www.tractorbynet.com/forums/john-deere
SOURCE: PEG PEREGO JOHN DEERE GATOR
Problem #1:If you have taken the high speed safety device off the stick shift(small red plastic block screwed on below the yellow stick shift housing) then your high/low speed switch has gone out. There are two motors(one on each back wheel) that both have to come on when in high speed. Only one comes on for low speed. It is the switch under shifter that is not spring loaded. hi/lo switch #MEPU0002 available at www.tigerimports.net for $11.00 plus $2.00shipping That is where I got mine.
Problem #2: Sounds like you need hi/lo switch and possibly forward/reverse switch too. Before buying forward/reverse switch try putting a little grease on the white plastic assembly that engages the forward/reverse switch between the top piece and the piece that pushes down on top of the switch. Sometimes they just stick enough to stop switch from depressing. It is the switch under shifter that is spring loaded.Forward/reverse switch #MEPU0003 $11.00 plus $2.00 shipping @tigerimports.net
SOURCE: John Deere Gator 4x2 - Left Wheel doesn't move when in 2nd gear
I would replace the high/low switch and the reverse switch. One time a replaced the high/low switch and the reverse switch quit on me 2 weeks later.
You can also get the Peg Perego Gator Shifter that upgrades the vehicle.
You can get the parts and repair help at this site
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-switches-and-shifters.html
They have helped me several times.
Hope this helps
SOURCE: How to do a Seat belt retrofit on older John Deere Gator??
The seat belt should just attach to each side of the seat between the green handles on each side, as long as it is a Peg Perego Brand.
I would also contact www.shopjandl.com
for additinal questions. They always help me out.
Hope this helps
SOURCE: fuel leak at fuel tank. L108 John Deere
Some of the older L-series had fuel lines come loose at the fitting just under fender deck to the left of the fuel cap.
SOURCE: battery is charged but car is still not working,
I have the switch go bad on the gas pedal. You can find a replacement here http://tigerimports.net/sunshop/
