Exercise & Fitness Logo
M
Margaret Whittaker Posted on Mar 02, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My smooth fitness elliptical ce74 does not turn on, only clics and the light on the HP usb port blinks but there is no readout on the LED display.
Nick Mork
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 05, 2019
Nick Mork
Contributor
Level 1:
Answers
Questions
0
Helped
632
Points
Hey, I've got the same problem with my smooth fitness ce74 elliptical. one day the screen froze up and after turning it off and back on, just the heart monitor port light comes on briefly when plugging it in. tried replacing a capacitor that was a little exposed, and replaced the 2032 battery, but no luck, still doesn't work. the elliptical itself still spins and you can use it at the lowest resistance setting, but no way to increase resistance without the console. Using a contactless voltage detector pen I can see power getting from the wall to the port on the back, to all the wiring in the console, and to the hand grip heart rate monitors. Were you able to fix yours?
Ross Metcalfe
Level 2:
Novelist:
  • Expert 135 Answers
  • Posted on Mar 07, 2019
Ross Metcalfe
Expert
Level 2:
Novelist:
Answers
135
Questions
Helped
79732
Points
314
It sounds like a console problem. Hard to diagnose over the computer.
Smooth fitness is out of business, so no parts are available.
Make sure you have the correct power supply and it is providing adequate voltage and amperage, outside of that, it sounds like a console issue.
5 Related Answers
Anonymous
  • 43 Answers
  • Posted on Sep 03, 2009
SOURCE: hp laptop wont display on screen but the power led
ur RAM might not be fit properly in the RAM slot. so place it properly in the slot.
Anonymous
  • Posted on Mar 11, 2010
SOURCE: My P.T. Fitness elliptical does not run smoothly
dont shop at canadian tire
Anonymous
  • 11 Answers
  • Posted on Apr 29, 2010
SOURCE: when i turn on my ecoquest, the fan will move an
possibly the control board, bad cord making and breaking.
Nicam49
  • 362 Answers
  • Posted on Jan 01, 2011
SOURCE: was wondering if there was expansion that fits the
Hello, some HP laptops have an option of a docking station.but am not sure what extra connectivity it he gives,maybe you can take a look on www.hp.com/support for details.
regards,
nicam49
Anonymous
  • 42 Answers
  • Posted on Aug 02, 2012
SOURCE: Are Smooth Fitness elliptical trainers good?
I have never used one; however I will send you a site with a lot of information about them, including customer reviews.
http://www.smoothfitness.com/ellipticals-machines/smooth-ce-80.htm?select_tab=reviews#reviews
My hp 17 inch m7 k211 dx will not turn on the power port light blinks 3 times. Help?
HP ENVY m7-k211dx Notebook PC?
those are called BIOS blink code errors.
take the battery out yet and try, batteries love to dye and short.
run on line AC power only that cure it?
only 1 year old , (or less) 1 is max. Aug 1015 RTM
the books on it are here.
https://support.hp.com/us-en/product/hp-envy-m7-k200-notebook-pc-series/7527539/model/7734388/manuals
with battery out, will the display even show BIOS messeages
see page 84 in the manual.
see this, ? quote:
To start Setup Utility (BIOS), follow these steps:
1.
Turn on or restart the computer, and then press
esc while the "Press the ESC key for Startup Menu"
message is displayed at the bottom of the screen.
2. Press f10 to enter Setup Utility (BIOS)
page 86 shows how to run BIOS base line Diagnostics.
that be next
page 4 in the service manual tells you the power light blink rules.
the lightening bolt LED binks , means no line power, and battery is now dead. is the power pack missing>? unpluged.
try a direct on connection to wall AC power known good?
the same light blinks i SLEEP mode.,
here is HP;s offical blinking (LED) lamp codes and cures.
http://h20564.www2.hp.com/hpsc/doc/public/display?docId=emr_na-c01732674
How do i fix a problem of green power led continuously blinking in Hp compaq nc6320 laptop even when the battery is removed and the motherboard is outside the case?
HP Notebook PCs - Troubleshooting LED Blink Codes or ...
h20564.www2.hp.com/hpsc/doc/public/display?...na...
Hewlett?PackardHP Notebook PCs - Troubleshooting LED Blink Codes or Beep Codes During Startup or Boot ... HP Pavilion and Compaq Presario notebook computers built in 2009 or later use blinking LEDS to identify ... Press the power button to turn on the computer, and look for blinking LED lights on the keyboard. ... Continuous blink.Missing: green ‎nc6320
HP Notebook PCs - Computer Does Not Start and Emits an ...
support.hp.com/us-en/document/c01732674
This document pertains to HP and Compaq notebook computers. .... light next to thepower socket or the light on the AC power adapter and note its condition: off, blinking, or constantly on. ... Battery power LED off, and Caps Lock/Num Lock off.Missing: green ‎nc6320
HP 6735s won't boot, power LED blinks 7 times - HP ...
Sole elliptical display first said Level Err and now says Motor Error. What can I do to fix this?
follow this steps and fix it. God bless you
Check power problems if the console on the elliptical machine does not light up. Make sure that the plug for the machine is secure in the outlet. If it is plugged in, ensure that the outlet is receiving power. Check the breaker to make sure it has not tripped off.
Be sure that you are using the correct adapter that came with the elliptical machine. Because different adapters are able to handle differing amounts of energy, the wrong adapter will not transfer electricity like it should. If the adapter is pinched or damaged, this could also alter its effectiveness.
    • 2
Make sure the correct adapter is being used if the resistance settings seem to be too hard or too easy. If the correct adapter is being used, reset the machine. To reset the machine, either switch the "On/Off" button or unplug the machine from the wall. Doing this will allow the device to reset itself to the default resistance. Turn on or plug the device back into the wall and retry all of the levels of resistance.
    • 3
Do not be concerned if you see small particles left on the guide rails. Over time, the roller wheels gradually wear down. When this occurs, they leave residue on the rails. Because this is considered to be normal wear, all you need to do to fix the problem is wipe the rails off with a damp cloth.
    • 4
Minimize the risk of receiving erratic readouts on the monitors by avoiding outside interference. For example, gripping the heart rate handlebars too tightly can affect the monitor. Similarly, the heart rate grips can be rendered less effective when there is too much vibration. Consider not holding these monitors throughout the workout to minimize vibration. The readouts also can be affected by jewelry. To minimize errors, take off rings and other jewelry before working out on an elliptical machine.
Show error
E indicates an Error condition.
1.Without turning off the product, disconnect the USB cable from the rear of the product.
NOTE:The USB cable connects to the port on the rear of the product. The port is labeled with the USB icon ( ). If your printer has a network or wireless connection, ignore this step.
Figure 1: Example USB connection (your product might not look exactly the same as this example)
2.Remove the cartridges from the product.
3.Wait until a message to insert the cartridges displays. If you do not see a message within a few minutes, skip to the next step.
NOTE:If your printer does not have a display, wait until the cartridge lights blink. If the cartridge lights do not blink within a few minutes, skip to the next step.
4.Disconnect the power cord from the back of the product.
5.Wait 60 seconds.
6.Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7.Reinsert the cartridges, and then close any open doors on the product.
8.If you receive a prompt to print a calibration page, do so.
9.If you disconnected the USB cable, reconnect it to the rear of the product.
10. Try printing again.
5.Wait 60 seconds.
If that doesn't work you can log on to HP.com/Support and Drivers.
Find your device and search the error codes listed.
You can also download a real good Utility, HP Print and Scan Doctor.
1helpful
Hp psc all in one-scanning stops abruptly.
I had the same experiences before.
What I always do is I unplug the scanner's usb cable and then switch usb ports till i find which port it will work.
In some cases this solution didn't work, I replace the usb cable with a new one. I always buy usb 2.0 compliant cable.
2helpful
2answers
HP 1280 PRINTER PROBLEM
Hi there there is this you can try it works with some
Step 1: Manual Temporary
1. Turn off the printer. And disconnect the printer cable.
2. Press and hold the POWER button, turn on the printer.
3. The indicator (L.E.D.) should be green.
4. Press and release the RESUME button , the indicator (L.E.D.) should be orange.
5. Press and release the RESUME button again, the indicator (L.E.D.) should be green.
6. Release both buttons.
step 2 : Software for Permanant
1. Reconnect the printer cable.
2.Open General Tools software and select (USB PORT2_bing.gif)
3.Choose (SET DESTINATION 1) And it should be reset.
Sofware Download "After service mode Pls use software for permanent reset
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
What is the green light that blinks on the left side of the printer just below the usb port?
Heartbeat LED
The heartbeat LED indicates that the formatter is functioning correctly. while the printer is initializing after you turn it on, the LED blinks rapidly, and then turns off. When the printer has finished the
initialization sequence, the heartbeat LED pulses on and off.
Attention light on hp 1115photosmart
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
2answers
HP Inkjet CP 1700 Inop
The digital readout on the CP1700 is a problem. I have replaced mine now 4 times at a cost of $90 each time, and I'm going to have to do it again or get the new 2800. Just wonder if the 2800 is going to have the same defect.
Top Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
