SOURCE: Amana D530M Dehumidifier won't run
We all appear to be in the same mess --Thanx Haier
This product says its Amana, but rest assured it is an Haier
The problem is most likely with the engineering design of the board. Im not an electrical engineer so be careful litning to me to closely :) There is only a half bridge rectifier on this board and 2 zener diodes that clamp down on the voltage. My guess on yours is the Zeners have been shorted and no longer clamping voltage down to aroun 24 volts for the low side of the board. I spoke with Haier and they have no schematics that state the zener specifications. They also said there was a 6 month backorder on ordering a new board. Oh and by the way if you want to order a new board and wait 6 months for the backorder it would cost you 75.00. All this jsut to repeat the problem again, because of bad design. O well ----- I wish products were not made better, so I wouldnt have to fill guilty about putting this in the landfills.
SOURCE: Amana NFW7200TW washer - door seal ring has detached
The ring is a clamp that keeps the rubber part, called the bellow, attached to the front panel of the washer. To reinstall hook the edge of the bellow around the lip of the opening in the front panel (the hole through which you put your laundry). Then take the clamp and seat it in the groove of the bellow behind the lip of the front panel. The spring on the clamp should pull the bellow tight to the opening of the panel.
Like so:
