SOURCE: pride mobility scooter. turn key on it keeps
Are you sure that it not in FREEWHELL mode, lever at the back, Regards
SOURCE: Electric 3 wheeled mobility scooter wont move
Look at the rear of the scooter, make sure the Free Wheel lever is engaged
SOURCE: 2005 Mini Cooper won't start battery is fully charged
I found solution. In my case problem was with connection next to the small electronic module next to the gear wheel. It is module directing red light in proper 'P', 'R', 'N' and 'D' letter.
SOURCE: E100 scooter wont run. Battery
It is possible the new controller is defective, however just because the voltage is showing 24v it may not be outputting the correct amount of amps so don not rule out batteries before checking the following:
To test a battery you need to 'load test' so (with help) connect the battery directly to the motor when weight is on the scooter to see if it will still pull.
Please also remember that you do have to push the e100 to 3mph before starting (many users do not know or forget this step)
SOURCE: battery fully charged, car wont start, cant remove key, 2004 cadillac cts
There is a magnetic switch on the 'park' position. The car only starts or releases the key in 'park' is enabled. Maybe this switch is not working! Try to replace it!
