Where the wires go into the operator head you need to find a button that he has an LED light next to it. It should say learn or learn code. Press and hold that button for 10 to 15 seconds Max usually, that should do it. You tap the button to program up the remotes and you hold the button to delete the remotes. Word of advice, it deletes every remote, keyless entry or vehicle that is programmed to at that time. Nothing will work after you hold that button down until you reprogram them in again giving them a new code. To reprogram, tap the button, do not hold the button and then tap remote control button that you want to program until the motor engages
SOURCE: Craftsman new 315MHz Garage door remote programming with old openers
The radio frequency has been changed so the two are not compatible.
SOURCE: I need to program a centurion gate motor receiver
Your gate controller reciever only has one code. You must set all the remotes to that code?
Press the outer 2 buttons untill the bink rate changes then release.
Press the button you want to train at the same time you hold down an unused button on one of your factory GDO remotes, hold untill flash rate changes.
Press learn button on GDO, press the button you just programmed in the Tahoe, should be programmed.
(Info should be in users manual under HomeLink.)
SOURCE: Is the Craftsman 139.53681B remote compatible w/ 139.53753 remote
They have changed the radio frequency and the two will not work with each other.
SOURCE: remote missing on old dominator garage door opener
This is the most complicated way I know of coding a remote and I am a tech. who does this all the time.
Turn power off. Wait 3 sec's & turn back on. Quickly press program button on back of box twice. Lights will flash, bottom light will stay on. Press program button twice, & No. 3 light will start flashing. Press and hold your remote button until light stops flashing. Code will be accepted.
