Https://support-us.samsung.com/nas/storage/201406271751003%5Estorage_attachment%5EHow_To_Reset_The_Ice_Makers_In_Samsung_Fench_Door_Refrigerators.pdf
make sure water filter has been changed also
SOURCE: Ice maker not working
I replaced both silinoids and the ice maker. The ice maker will freeze water but not fill with water. My refridgeratoor is an a Amana
SOURCE: Ice Maker not working
Start by cleaning the condenser with a brush and a shop vac. Then get some nickleguard ice machine cleaner and wash the units plate's down going by package directions, then retry before calling a tech. It may start working but if it does not then it may save you some money by having the unit clean before the tech gets there. Ice machines are not a DIY repair. Sowwy
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: GE model GSH25JFTACC ice maker not working
When an ice
maker is producing ice poorly--when it produces just a few cubes or
none, or when the cubes are too small--it's usually because of a
clogged water line or a defective water inlet valve.
First,
check the water line attached to the back of the refrigerator for good
water flow. To do that, first turn off the water supply valve. Then
remove the water line from the back of the refrigerator. Next, place
the water line into a bucket and momentarily turn the water valve back
on to test the flow. If the flow is poor, you need to repair, clean, or
replace the tubing or the shut-off valve that supplies the water. If
the flow is good, you may have to replace the water inlet valve.
SOURCE: Kenmore refg. model # 106.56544400 ice maker
Water valve is a dual valve. One for water, one for ice. Switch the wires to test.
SOURCE: Our ice maker is making 5-10 cubes per day. Ice
OK, Have a look (if you can) and see if one of the water jets might be broken, or if there might be a defect in the tray. I can't help any further i'm afraid.
What is the complete model number of your unit?
