Tools & Hardware - Others Logo
Donald Hyde Posted on Mar 01, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can I order a replacement blade for a Rainco R1B 7C - 16 stapler?
Kardoc
Level 3:
Top Expert:
  • Master 7,501 Answers
  • Posted on Mar 02, 2019
Kardoc
Master
Level 3:
Top Expert:
Answers
7501
Questions
0
Helped
2755098
Points
58317
Try your nearest hardware store.
Testimonial: "My local hardware stores don't sell a staple gun that costs over $100, matter of fact very few major store sell them. It's an upholstery gun. Furthermore, this gun is over 10 years old & heavily used. I found a store online, cost for the blade is $25 shipping about tax $10. Trying to save a buck... thanks for your response."
2 Related Answers
Anonymous
  • 4 Answers
  • Posted on Aug 22, 2009
SOURCE: FixYa RainCo R1b 7C -16
Hello; If the gun is AIR operated, adjust the AIR presure DOWN on the regulator on the air compressor tank? If it is electric operated! there should be a depth DIAL (say 1-8, 1 being the least depth and 8 being the most; depending on the hardnest of the item being stapled) trial & error to be tried on a scrap piece first......! hope this helps, John.
Testimonial: "Thanks for the help. I was geting ready to file the plunger."
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Apr 04, 2017
SOURCE: I need O rings and lower bumper for Rainco R1B 7c 16 uphostery stapler
"O" rings are sold by diameter, thickness and type of material, any auto parts store can likely match up what you have. I would use a material called "Viton" not just rubber, holds up better to chemicals
What should I do if my brand new Fasco pneumatic upholstery stapler is leaking air through the tail end...not the hose, but the two holes in the handle? Any suggestions?
Hi Anonymus,
What's happened if the driver blade has stopped in mid stroke, the air will escape. Quickest was 'round this is to take the airline off the tool, then find some scrap wood, place the tool on it as though you're firing it, and in THIS ORDER... pull the trigger and re-connect the airline at the same time. This usually sorts this out. Regardless of the tool make and model this will happen to most users sometime....
Leigh Co Limited
Rainco stapler parts
Needs o'ring kit and lower bumper.
Staple jams by driver blade in gun and I have to dismantle nose to get it out. Empire Rainco 7-16.
The problem is wear on the sides of the driver blade. With the constant up/down movement of the driver against either side of the nose plate, it eventually narrows enough to allow part of the fine wire 71 series staple to find it's way between the driver blade and the inside wall of the nose plate. A new driver blade cures this completely. Rainco tackers have become a bit rare but the good news is, they're actually manufactured by Fasco and the Fasco driver fits into the Rainco piston by the removal of a single pin to allow the old blade out, replace with the new Fasco blade, re-insert the pin into the piston, then re-assemble the gun and you're away.
I need the schematic for a Fasco FIB 7C-16 fine wire upholstery stapler...and, if available, an owners manual. My stapler is not shooting staples and I have tried everything that is on the troubleshooting...
Hello from FASCO ITALY. Pls let us have yr complete email address and we will send you the manual and the schematics. Our email is [email protected] best regards FASCO
Feb 12, 2011 • Garden
3helpful
2helpful
Schematics on fasco air stapler #F1B 7C-16
I can e-mail you schematics. I have all Fasco & Rainco parts for this tool and more in stock!
Top Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
