SOURCE: how do you get to the file valve? Do I remove the rear panel?
You get at the the valve by removing the washing machine cabinet, not by taking off the back. The process is described well in pictures here. It's not a difficult process at all, and you can save quite a bit by doing this repair yourself.
SOURCE: Rattle inside dryer drum
remove the front cover and then you can access the top cover screws to open top then you can locate and tighten screws
SOURCE: passenger door panel removal. it seems like the
Hi!!
Here is a blow out diagram of the door panel for your vehicle.
If you feel you need step by step instruccions with illustrations to R&R the door panel, click the following link http://www.autozone.com/autozone/repairinfo/repairguide/repairGuideContent.jsp?pageId=0900c1528006f79c
Don't forget to rate this post!! Good Luck!!!
SOURCE: Inside the rear bottem access
The following web blog on the noise and problem, has a consensus about it:
http://servicetechhelp.com/discus/messages/2801/6894.html?1286386585
Basically, the compressor will have to be replaced to stop the noise, but some people have used theirs for years with the same problem. Basically, it won't hurt anything to run it as long as it will run, if you can handle the noise.
There should be a thermostat adjustment in the fridge compartement
