The sound bar remote doesn't work!!!! I am trying to use my Fire Stick 4K remote. I get sound but can't control the volume. Supposed to be compatible with my Vizio tv go into audio on tv and activate sound bar
This is a new feature (volume control) on the remote. See https://www.cnbc.com/2018/10/03/amazon-fire-tv-stick-4k-remote-volume-buttons-rejoice.html
See here for quick set up guidehttps://s3-us-west-2.amazonaws.com/customerdocumentation/Amazon+Fire+TV+User+Guides/Amazon+Fire+TV+Device+Documentation/Amazon_Fire_TV_Stick_with_Alexa_Voice_Remote_US.pdf
SOURCE: I HAVE A VIZIO SOUND
Hello, Daniel Busa with Dish Network's customer service try these steps if the remote will program this will do it
SOURCE: I Have a 5.3 IR
lojr, (VCR button instead of TV button)
We have code to use with amplifiers, TVs, VCRs, and DVD players. I do not have a code that will work on this sound bar. What is the code you are trying to use? Did Vizio supply a code with your sound bar. They do have codes to use for their TVs to program DISH remotes. Please let me know if you have a code or you can contact Vizio to see if they have a code available.
I have provided the Power Scan instructions on programming the remote to a sound bar. Use the VCR button to attempt to program the sound bar.
If you have further questions, please post it here.
Ray Calo
DISH Network - Executive Offices
Power Scan Instructions Power Scan Instructions
1. While at the sound bar location, point the remote
at the sound bar. Press and hold the VCR MODE button on the remote until all four MODE
buttons at the top of the remote light up.
2. Press the RECEIVER POWER button on the remote.
3. Press the UP ARROW on
the remote, about one press every two seconds. Stop as soon as the sound bar turns
off. This process may take several minutes.
4. Press POUND (#) on the remote. The VCR MODE button will
flash three times.
5. Press VCR MODE button, then red TV button on the remote to turn on the sound bar. Press
VOLUME on the remote to confirm the remote controls the sound bar. If this does not
work, return to Step 1.
Remember to press the SAT MODE button to return to the Satellite mode to change channels.
SOURCE: I recently bought a Logitech Harmony One universal
Great remote but not always easy to find right category for device.
Had a look for you and sure enough the device IS listed in data base under AMPLIFIER- then select amplifier again and input vizio for make and soundbar for model and click next.Problem solved!
SOURCE: Wanting to program my dish
I don't show we have any codes for the Vizio sound bar. Have you checked your Visio manual for the code; I know that Vizio TVs provide codes for different providers. If you still can't find a code, I have provided instructions on how you can perform a power scan for programming the remote.
Address To Other Equipment Using Power Scan
Then Press STAR (*)
SOURCE: VOLUME CONTROL ON TV REMOTE CONTROL DOESN'T WORK
Hello
Your remote control needs cleaning. Just go to this link and see the details. OK.
http://www.fixya.com/support/r10192276-cleaning_remote_control_handsets
