SOURCE: Clearing memory 0n sharp XE-A203
save your program data if you wish keep it on a sd card
remove the batteries and unplug. wait 5 minutes,, put key in, turn to reg and plug in.
you should get 3 beeps... all is set to default now and ready for programing
here is a link to the software
http://www.sharp.ca/downloads/default2.asp
SOURCE: Sharp XE-A203 software compatibility with vista 64-bit
to get the register to communicate with your vista or to even run the customer support tool software you will need to uninstall, reinstall, right click on the icon on your desktop, choose properties,in the compatibility box put a checkmark in the "Run this program as administrator",
everything should operate normal now with no errors
SOURCE: Driver for Sharp XE-A203 Easy Programming Tool download
Download it here... http://www.sharp.ca/downloads/dwnfile.asp?FileID=2402&FileName=XEA203_Cust_supp_tool%20.exe
SOURCE: Sharp XE-A203 Cash register Error message 3.2
You have logged yourself out of the machine. Press CL then 1 then CLK# or CASH#
