SOURCE: connecting throttle linkage on brigs & stratton snowblower
here is a site that may help you. I hope so, these things can be a real pain in the neck. let me know if you need any more help, I would be glad to help you.
http://wssemw.arinet.com/scripts/EmpartISAPI.dll?MF&app=EWSS&session=9ea7684f-6a4b-45b9-89c9-d4a5ad4e20da&cat=27&TF=epcFrame&assem=62752&highlightNode=No&selAssem=123060&mdDescrip=130232-0676-99
SOURCE: I do not have a manual for my craftsman snowblower
go to searspartsdirect.com. Put your model in and you will find a listing for wheels. The diagram shows one side held on by a bolt and nut; the other side by a clevis pin. Check it out.
Good Day.
SOURCE: need manual for craftsman snowblower 42 or parts below
Ok
That Snowblower is made by Agri- Fab for Sears/Craftsman .If you go online to the agri-Fab website it is possible to down load the manual or if you email them they will send you a copy. I have dealt with them.They have even sent me missing parts. GOOD LUCK
Mike
SOURCE: Briggs and Straton 8 hp, craftsman snowblower stalls
Sounds like you coil is over heating after running a few minutes. The windings are seperating, then when it sools they make contact again. Try replacing the coil.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
SOURCE: Craftsman II model 917255911. Will
I couldn't find the manual for your tractor but I did fiind one for a 917255917 model it calls for a 71-25231 snow thrower. The 842 model you listed must not be complete number. There are several different models that start with 842. Does your tractor have the horizontal engine that has clutch on front, and drive pully on rear of engine? I used to have one like that and I had a sears blower on it. You'll need wheel weights and chains too.
