Searspartsdirect.com may have it in their parts listing for your model #.
Earlier question concerned self cleaning oven.
https://products.geappliances.com/appliance/gea-support-search-content?contentId=19655
https://www.hunker.com/12389091/ge-profile-oven-cleaning-instructions
SOURCE: GE Profile-electric oven
Copper, F3 means oven temp sensor is open. You need to replace the probe. Easy job. Part number I have for this is WB23X5340, but double check your model number. Look it up on the net to see what you are going after...Catriver..post back
SOURCE: GE Profile double Built-In Oven error Code
According to the GE User manual... any F# error code means you have a function error and they suggest you press the CLEAR/OFF pad and allow the oven to cool for one hour. Then put the oven back into operation. If the function code repeats, disconnect all power from th eoven for at least 30 seconds and then reconnect it.. If it still comes back.. call for service.. however it has been my observation that F0 is usually a shorted off key on the keypad. Hope this helps..
SOURCE: ge profile oven loc
hey - I figured it out! hold down the 9 and 0 at the same time for 3 seconds! or it might be another combination depending on your oven - it is probably the 2 keys that the messge is under
Yay!
Island2
SOURCE: F7 Code on my GE Profile Oven
F7
A = Function pad button stuck or
B = Bad clock
Unstick button or
Replace Electronic Range Control (ERC)
SOURCE: Ge Profile built-in 27 inch wall oven -- When I
f9 means your control panel needs to be replaced..chances are part is not covered and if it is the only way you can obtain it is through having service
