Building Materials Logo
S
Sam Mayeda Posted on Mar 01, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I program a Chamberlain Wireless keypad to a garage door with DIP switch operations.
Steve Pack
Level 3:
  • Building Mat... Master 7,121 Answers
  • Posted on Mar 01, 2019
Steve Pack
Level 3:
Answers
7121
Questions
Helped
2271649
Points
27880
You don't, they are not compatible. You will need to find one with wires.
5 Related Answers
Anonymous
  • 11 Answers
  • Posted on Jun 24, 2008
SOURCE: Sears Craftsman Garage Door Opener Wireless Keypad Model and a LiftMaster Chamberlain Professional Garage Door
I had the same frustrating dilemma with my Craftsman LiftMaster garage door and Keypad, Model 139.53754-01 (dated 10/06; and has the # 315 MHz).
To resolve “the dilemma”, grab your keypad, climb up on a ladder to access the garage door opener’s motor unit. On the right side of the motor unit, remove the white plastic casing by pressing buttons on each side and pulling down. This will expose the programming area, and for our purposes, the “Learn” button.
1. On the motor unit, press and release the “Learn” button. The Learn indicator light will glow steadily for 30 seconds.
2. Within 30 seconds, enter a four digit personal identification number (PIN) of your choice on the keypad. Then press and hold the ENTER button.
3. Release the ENTER button when the motor unit lights blink. The code has been “learned”/stored/activated.
Good Luck, and I Hope this Helps!
Gail
For possible future reference:
How to change an existing, known PIN
(Changing an existing PIN can be done with the wireless remote keypad, and does not require access of the motor unit.)
From the keypad:
1. Enter the four digits of the present PIN, then press and hold the # button. The opener light will blink twice. Release the # button.
2. Enter your new 4-digit PIN and press Enter. The motor unit lights will blink once when the PIN has been “learned”/stored/activated. Test by entering the new PIN, and pressing Enter.
Anonymous
  • 1550 Answers
  • Posted on Nov 21, 2008
SOURCE: Programing limits on a Grifco MK3 Garage door Operator
You can get manual from the link below
Garage door
glenmann62
Glenn Mayer
  • 91 Answers
  • Posted on Mar 04, 2009
SOURCE: Chamberlain garage door opener unit-is it compatible with craftsman keypad?
Hello,Linda well this is your lucky day ,I have installed garage door openers for sears for 10 years and i can tell you that craftsman,chamberlain ,and liftmaster are all the same machine and manufactured under the liftmaster name , if you buy it from home depot it will be a chamberlain ,if you buy it at sears ,it will be a craftsman, and if you go to commercial building supplier it will be a liftmaster! now getting that out of the way even though they are all compatible ,there is one thing that stands in their way and that,s time ,For example if your chamberlain machine is 5 years old and you went to sears last week ,the chances of the frequency being the same are not good , most likely you have the wireless keypad , one way to test the sears keypad against the chamberlain machine is to locate the smart button on your machine ,this button allows for programming of remotes and keypads , to test and see exactly what im talking about take your remote and locate the smart button ,if you have three buttons on the remote press one of the buttons that are not being used on the remote ,above the smart button their will be a blinking light ,if you press your remote button you will notice the light go from a blink to a rapid flash , This is telling you that you are sending a signal for programming to the machine , well the keypad is exactly the same all you have to do is push the enter button on the keypad and have someone watch for the rapid blinking light ,if they are compatible the light will blink rapidly on the machine so all you have to do now is have someone press the smart button once on the machine your indicator light will now be a solid light you will have approx 60 seconds then to put a 4 digit code in the keypad and then press and hold down the enter button on the keypad , at this point you will notice the lightbulbs on the chamberlain machine to shut off and come back on this is to tell you that the machine accepted the code , after thats been done you can use your keypad , you can also find the owners manual to the chamberlain and follow the same instructions to programming the remote , they are identical in programing , if your keypad is not the same frequency you can also tell by looking at the frequency code on the backside of the keypad and also the chamberlain unit usually where the light bulb is will be its code
Anonymous
  • 143 Answers
  • Posted on Sep 06, 2010
SOURCE: How to set dip switches on remote for Chamberlain Liftmaster 1000
I would go with a chamberlain clicker on this issue. These remote are phased out and the 9 dips don't work well with them. Thanks BB
Anonymous
  • Posted on Dec 07, 2012
SOURCE: I have LiftMaster garage door model 41A3039 and
i have a liftmaster 41A3039 i cant find the program button on it
My craftman 139.52606 opener does not have a learn button to set pin on keypad. I had keypad working at one time but since I changed the battery I can't rember how to reset the keypad.I also changed...
If the keypad is hardwired, do this:
To program the keypad, first unplug the garage door opener from the electrical outlet. Next, remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next, enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
1helpful
The wired keypad (Chamberlain) of my garage door is not working. The red light on the keypad keeps blinking. Can someone tell me how to fix that? FYI, the garage opener, the remote, and the wall unit all...
You can try programming the keypad using the procedure below.
How to reset code for keypad after reattaching wires
1helpful
How to change the password on the key pad for a garage door opener model number 13918415
Quick response. Thanks.
To program the keypad first unplug the garage door opener from the electrical outlet. Next remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next enter your desired four-digit PIN into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
2answers
I have LiftMaster garage door model 41A3039 and Chamberlain wired keypad--how do I change the keypad code to open the garage door
To program the keypad, first unplug the garage door opener from the electrical outlet. Next remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
Chamberlain CLT1D Remote Problems
Its very possible for someone esle to have your code I would say try two things. The first thing is too check your wall button wire shake it is a little make sure there are not cuts or staples in the wire its self cause it to short out and run. Then change your codes is pretty easy on the back of the opener unit its self there are the dip switchs you will most likly need a step stool. Just move 2 or so of the dip switchs and then move the same ones on your remote. On your remote the dip switchs should be undernether the batter cover
Top Building Materials Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Building Material Expert? Answer questions, earn points and help others
