JUST REPLACE NEW LAMP
SOURCE: Reset Lamp Hours Timer
This works on a couple different Toshiba models -- might work on yours...
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go. It is done.
SOURCE: lg llp xg22 lamp reset
These instructions are taken from page 44 of the User Guide.
Turn the power off but keep pluged in. Press the buttons on the control panel in the sequence as below.
Press "Up Arrow", Press "Down Arrow", Press "Left Arrow", Press "Right Arrow", Press "Menu", Press "Enter".
Lamp time will be initialized
SOURCE: SHARP XV-Z91E Projector Replaced lamp but
hold down menu, enter, and down arrow, then press power. this is the only way to reset the lamp timer. if it won't turn on and there are no leds lit, you may have to reset the bimetal breaker. to do so, remove the 6 bottom screws and the top 2 screws on the back panel, and remove the top case. on the front side of the lamp housing, you will see a red button. press it. if it clicks, it is reset. if it doesn't, it wasn't tripped, and you have a power supply issue.
SOURCE: Lamp Timer Reset...
Hello, does any1 know how to reset the lamp timer on a LG RD-JT31? I want to get rid of the Replace The Lamp sign.
Regards Linus
SOURCE: How to reset the lamp timer count on a LG rear projection TV
1. Press the OK or enter button on the front panel and MUTE button on the remote control simultaneously (About 5 seconds). 2. Press the VOLUME (>) button. 3. Press the OK or enter button.
Lamp time will be reset.
