SOURCE: Culligan Estate 2 Model 01010091. Back wash will not stop.
The back flow filter is clogged. It will need to be cleaned out. When it is clogged the pressure reverses so the valves will stay open to clean without shutting off
SOURCE: my Medallist culligan water softener had run for
You should have a bypas valve or valves at the back of the unit where the water pipes go in and out of the unit...
Shut off and bypass the unit till you can get it fixed...
heatman101
Testimonial: "Thank you. Now that I have done this the water has stopped running as I switched it to the hard water cycle.."
SOURCE: water softener is inoperative and is displaying E1
Usually, an E1 error code means the circuit board is bad. Try unplugging the unit for 5 minutes. Upon plugging it back in, if it does not reset itself, that means you need a new board. It is really easy to replace ( just a few wires) and will cost around $160.
SOURCE: o-rings leak on a culligan mark 50 water conditioner
Neither a manual or parts are available for this this valve. It is obsolete.
RJ
SOURCE: Need a seal kit for a Culligan Mark 89
Your local Culligan dealer is the only place to get one. You need the retrofit kit to prevent the shaft of sealpack from bending.
RJ
