Golf Logo
I have a ez go txt with cables to put in forward and reverse but it want go into ether one just seems to stay in nuatral what do I do
4 Related Answers
Anonymous
  • Posted on Oct 24, 2009
SOURCE: goes forward but not reverse??
I jest want a printe down loaded to my conputer.
Anonymous
  • 440 Answers
  • Posted on Jan 07, 2012
SOURCE: clutch gl1000 honda creeps when put in gear hard to find nuatral sat 10yrs
Get car oil out - friction reducing properties ruin wet clutches - put bike oil in
Make sure cable is adjusted properly
Plates may get stuck together after time unused - see my tip for quickly releasing seized clutches
Ride Safe
Bike-Doc
adamfjeld
Adam Fjeld
  • 1508 Answers
  • Posted on Jun 08, 2012
SOURCE: Gator 6x4 tranny problem
try posting the question in the forum for john deere gator and not the forum for the kids john deere gator
john h
  • 29492 Answers
  • Posted on Sep 26, 2018
SOURCE: Do you repairs golf cart?
fixya does not physically do repairs were an online repair forum manned by volunteers
What part of the forward and reverse switch is loose on a B&D corded drill Dr560.
What to do next, find your receipt and take it back to where you purchased it and get another one. Make sure the new one works right before you leave the desk of store.
1984 EZ GO WILL GO NORMAL SPEED IN REVERSE BUT NOT IN THE FORWARD DIRECTION
I am guessing that your cart has 3 batteries on each side and the controls are between the batteries. If that is the case there is a reverse cable that is not connected to the main positive but to another positive battery post. If this sounds like your cart then I would check the condition of the batteries from where the reverse wire is connected and to the main positive battery. Some older carts use less batteries for reverse but uses all six for forward.
Hope this helps.
Aug 31, 2015 • Golf
2helpful
1helpful
2answers
Clutch gl1000 honda creeps when put in gear hard to find nuatral sat 10yrs
Ride Safe
Bike-Doc
Jan 07, 2012 • Motorcycles
I have a 95 model 25hp mariner when selecting neutral i can only do so by going to reverse first. Going from forward to neutral it still stays in forward gear.
hi disconnect the remote gear cable on the motor then try it if you can get all gears and neutral without going into reverse all is ok put the cable back and ajust it if it won't work the control box is worn hope this helps merlin v12
Aug 26, 2009 • Boating
2answers
94 v6 camaro automatic.. no reverse or neutral.
Sounds like you may have burned out the reverse clutch pack inside the transmission by going from drive to reverse. I would recommend seeing a transmission shop for verification. Hope this helps
I have a problem in sorting
If your using windows:
Open cmd.exe (program files>accessories>command prompt)
use the sort command in this syntax:
sort "path name and or file name"
you may also use file exports like this for example:
sort birthdays.txt > sorted birthdays.txt (single forward will write over old files and make new ones)
sort birthdays.txt >> sorted birthdays.txt (use double forwards to made amendments to the file)
the "/R" function will reverse the sort order, for example:
sort /R birthdays.txt
thats all, hope this helps. I cant do much else with the information given.
Top Golf Experts
Kardoc
ADMIN Andrew
ADMIN Andrew
vince
Are you a Golf Expert? Answer questions, earn points and help others
