Hi! Please check the troubleshooting part of the manual to a similar JENN-AIR fridge https://manualsbrain.com/en/manuals/947419/?page=15
SOURCE: temperature 94 in refrig. normal in freezer
Check to see if refrigerator door is lower than freezer door. If so remove toe panel, (bottom front). Under refrigerator door hinge at bottom right is adjuster for door. Adjust upward so door is even. On some models when door is too low it causes light to stay on some times, raising ref. temps.
SOURCE: JennAir #JCD2389GES not cooling refrig at all.
Well guess what. Jenn Air / Maytag now has this issue as a recall. So just call them and tell them the fridge is not cooling. They will schedule a recall service appointment. Do be sure they schedule it as a "recall" service appointment or you will be charged.
That sure beats pulling out the hair dryer every time it happens!
Service number is 1-800-462-9824
Good luck
SOURCE: water laeks into the refrigerator part of refrig
you are probably right. the drain is located behind the back wall of the freezer section, under the evaporator coil. simplest fix is to remove the rear panel and unplug the fridge,prop the doors open and let it melt on its own, a hair dryer or hot water may speed up the process.
SOURCE: Whirlpool Side By SIde Refrigerator Freezer stopped cooling
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
SOURCE: have kenmore refig model 59671103101 refrig
if the freezer is fine, check for air flow to fridge. if you get none, see if there is any frost on the back wall of the freezer. if there is some frost, the coils are iced up and need thawing. if there is no frost, there may be an obstruction in the vent. also may be thermostat in fridge- it opens and closes the vent from the freezer.
