Question about Amana Washing Machines
Got amana front load washer model nfw7200tw and door is locked has a humming noiss but wont spin
    Top Expert:
  • Amana Master
  • 61,791 Answers
MIGHT NEED MOTOR OR A NEW BELT WITHOUT SEEING IT CAN NOT GUESS SORRY
Posted on Mar 02, 2019
3 Suggested Answers
SOURCE:
SOURCE: amana front load washer door locked with door open
To get the front off. (All screws look to be #2 Phillips Screws)
1. You have to unscrew (2) phillips screws from the back that holds the top on.
2. Slide the top off. (slide towards the back)
3. Then where the control panel is there is about 4-6 screws holding that plastic piece on, take those out this will allow you to pull the control panel up and out of the way.
4. At this point you can unscrew the 4-6 screws in the door area that holds the front of the washer on, once you unscrew those screws there is a tab that you have to lift the front over to pull the front off. This will allow you access to the locking mechanism.
5. There are only 2 screws holding te locking mechanism on.
Posted on Nov 18, 2010
tbirdfan1
  • 3051 Answers
SOURCE: amana front load washer error code "nd". Door is
Hello there and welcome to fixya
From what you're describing it sounds like the drain pump is blocked. The nd error code indicates "no drain". If the unit can't drain it won't spin. You're going to have to slide the washer out far enough to remove the rear panel; be careful not to damage the floor. Once you get the rear panel off you will see the pump. Be sure to have plenty of towels & a small container to catch water. I am sending you instructions from the service manual to remove and replace the pump. Another possibility is the drain line is blocked or something is stuck in the tub to pump hose.
Posted on Nov 05, 2011
Whats so tricky about the repair?
Amana Washing Machine Parts - RepairClinic.com
www.repairclinic.com/Shop-For-Parts/.../Amana-Washing-Machine-Parts
Huge selection of Amana Washing Machine parts in stock. Same day ... A small leak in front of the washer could be caused by a defective pump. OEM Part ...
www.repairclinic.com/Shop-For-Parts/a11/Washing-Machine-Parts
Find your parts fast and repair your Washing Machine with our free repair help. ...Admiral · Amana · ARDO · Asko · Bosch · Crosley · Danby · E-Wave · Electrolux · Estate ..... A small leak in front of the washer could be caused by a defective pump..... Washing machine door lock and switch assembly for front loading washers.
How To Fix Front Load HE Washer Does Not Dispense ...
removeandreplace.com/.../front-load-he-washer-does-not-dispense-deter...
May 15, 2015 - HOW TO REMOVE WASHING MACHINE SOAP DISPENSER ...
Jan 10, 2016 | Amana Front Load Washing Machine Washer...
When I plug my amana front load washer in it hums and wont start the only light that comes on is the door lock light and its blinking
well a hum usually is not a good sign, do u smell anything when it hums? sounds like a bad motor or bad motor windings to be precise.
Nov 03, 2014 | Amana Front Load Washing Machine Washer...
Can an frigidaire X091307954 dryer be stacked on a Amana NFW7200TW 3.5 Cu. Ft. Front Load Washer?
this is possible, youll need a kit that sets on top of the washer,check back where you bought the washer and dryer, they make a washer and dryer combo thats one peice, they are smaller however
Jul 13, 2013 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
Water fill and start
if the water valve is bad it will hum and no water will enter the washer,first thing is to see if it's a problem with the houseicon1.png water valve or the washer valve,shut off the water supply,reomve the water hoses from the back of washer,mark the hoses so they go back on the same way,stick the hoses into the washer or a bucket and turn the water on,if water comes out of hoses then you know the problem is just the washer,check the valve,look at the screens where the hoses connect to the valve,usually sediment gets in there and the valve on the washer has to be replaced,on some the screens can be removed and cleaned,also you say you have trouble with the lock,what's humming is it the lock or the valve,if you turn it to drain and spin will it run?you could have a bad door switch,if door doesn't latch washer won't run but most likely bad water valve
Jun 15, 2013 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
NFW7200TW hums and does not turn or fill with water
if it doesn't fill the water valve will hum,first thing is to see if it's a problem with the house water valve or the washer valve,shut off the water supply,reomve the water hoses from the back of washer,mark the hoses so they go back on the same way,stick the hoses into the washer or a bucket and turn the water on,if water comes out of hoses then you know the problem is just the washer,check the valve,look at the screens where the hoses connect to the valve,usually sediment gets in there and the valve on the washer has to be replaced,on some the screens can be removed and cleaned,also you say you have trouble with the lock,what's humming is it the lock or the valve,if you turn it to drain and spin will it run?you could have a bad door switch,if door doesn't latch washer won't run but most likely bad water valve
Door latch stays locked
remove the top and there is a manual release for the door near the latch. You will need to replace the door lock. Here is a link to the part.
Oct 17, 2012 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
Amana washer model NFW7200TW drain filter
Go to www.repairclinic.com and enter NFW7200TW. You will be presented with a list of common repair parts and may be able to view a generic Amana video showing disassembly and parts identification.
May 17, 2012 | Washing Machines
My amana front load washer wont spin and is showing an "nd" error message. what does this mean and how do i fix it?
Hi
Thanks for using FixYa. From what I understand the error code ND means “No Drain issue”. You’ll need to check for any restriction in pump assembly. It can also be due to a restricted drain hose or loose wire at pump. If after cleaning the drain hose the issue is not resolved then it means the pump has gone bad and unfortunately needs to be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 28, 2010 | Maytag NFW7200TW Front Load Washer
Amana NFW7200TW washer - door seal ring has detached
The ring is a clamp that keeps the rubber part, called the bellow, attached to the front panel of the washer. To reinstall hook the edge of the bellow around the lip of the opening in the front panel (the hole through which you put your laundry). Then take the clamp and seat it in the groove of the bellow behind the lip of the front panel. The spring on the clamp should pull the bellow tight to the opening of the panel.
Like so:
Jun 11, 2010 | Maytag NFW7200TW Front Load Washer
Amana front load washer door locked with door open
Feb 25, 2009 | Amana Washing Machines
Washing Machines Logo
29 people viewed this question
Top Amana Washing Machines Experts
Sal De
Mike
Gerry Harvey
Gerry Harvey
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
