SOURCE: I need an instruction manual for a New Home model SW
I remember stocking that model, the only place you may get one is www.sewingonline.co.uk/instructions or www.sewusa.com
SOURCE: Hello I just got a new home My Lock 334D machine.
Un-thread and then see if the machine will run without thread.
If not, it needs to go into the shop for repair.
If it does, refer to the manual. Or, the guide that should be printed on the inside of the serger's door.
Raise the thread antenna to it's highest position. Keep it at this position when serging. If lowered for storage, and threaded, be sure the thread does not tangle around the antenna arms.
Raise the presser foot.
Open/set the tensions to zero.
Raise the loopers to their highest level - there may be an indicator mark on the side of the serger to match with a mark on the handwheel to help with this.
Start threading from the right to the left; upper looper first.
After threading, reset the tensions to a medium number, lower the presser foot and stitch a chain to test the stitching.
Serge a scrap and adjust the tension as necessary.
Once you get the serger working as it should - don't run out of thread. Tie off, open the tension, raise presser foot and gently guide the new thread through the threading process.
When changing the thread or removing the thread to store the serger, cut the thread at the antenna, leaving thread tails for tying off the new thread.
If you do not have Nancy Zieman's "Serge with Confidence", you will find it much more informative than the average serger manual.
SOURCE: I need the instruction book for the New Homer
Well you can please follow the below link to get your instructions manual -
http://www.devicemanuals.com/guide/Balance/A&D/A-D-HF-3000-Balance-Instruction-Manual-English-==TWpZMk5EWXg=.html
Good Luck!!
Thanks for using FixYa!!
SOURCE: want to buy a new sewing mechine for own and commercial use
If you sew well and use to a strong industrial machine get a Juki DDL8700 series, it's a well investment. But if it's a regular portable home machine white brand is good enough. Maybe you can buy the one with more than just a straight stitches, just for fun. If you are new to sewing make sure whatever sewing machine you buy it come with a manuals. Good luck!
SOURCE: WHERE CAN I FIND A MANUAL FOR MY SEARS KENMORE SEWING MECHINE MODEL NUMBER 148.14220
ebay
sewingpartsonline.com
sew4less.com
sewusa.com
sewvacdoctor.com
a1sewingmachines.com
