SOURCE: The belt came off my mower and I need to know what
Try going to kubota.co.uk and see if a diagram is available there.
SOURCE: I need a free diagram of the belt assembly for a
Good luck. It looks like the diagrams are all locked down by Kubota.
I might recommend looking throught the listings of "kubota empart" empart is the parts lookup system used by dealers and there are sites out there that may have kubota listed.
Joe
SOURCE: I have a Kubota TG1860
belts,solenoid,ignition switch and the PTO, you can hook 12v directly to PTO and see if it is engaging, the ignition switch feeds 12v to the PTO, the switch/solenoid engages with the help of the pulleys and belts, just a matter of figuring if its the belts(or in may cases the tesioner pulley) Hope this helped Tim
SOURCE: belt diagram for a kubota tg1860
I have a Kubota TG1860. I had it serviced and after 20 hrs, the belt burned and frayed. This was replaced and then after 2 hrs of mowing, the same thing happened.
SOURCE: how to install main drive belt on a Kubota riding mower model t1880
Go online or call Kubota. They'll send you a diagram if you give them the model #.
