Watches Logo
Anonymous Posted on Feb 28, 2019
How to get the Bezel off
This watch has no notches. How do I get the back off to change the Battery?
Thomas Perkins
Level 3:
  • The Master 15,088 Answers
  • Posted on Feb 28, 2019
Thomas Perkins
The Master
Level 3:
Answers
15088
Questions
0
Helped
3388660
Points
54869
1 Related Answer
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Mar 30, 2010
SOURCE: cannnot find notches in back of watch. I have a
If there are no notches on case back, your 3 point tool has no use. You need watchmakers knife (or pen knife) for opening case back. Use an eyeglass and carefully examine case back all the way around. You will find tiny groove ''lip''. This is exact point where to insert the blade and pry up. Rate me, plz.
How do u change battery in yves camani watch please
For a quality watch like that I would recommend using a specialist watch repairer as they can reseal the watch to be water tight after the battery is replaced.
Could you possibly comment below with a photo of the back of the watch?
There are three main types of watch back plate. Push fit, screw down and screw on.
Push fit is usually a smooth back cover with No notches or grooves. These can be gently levered off to replace the battery then pushed down to 'click' back into place. Some have a slight notch on the body or back plate to make removal easier.
Screw down back plates have dimples or notches at regular places around the edge. This is to allow grip to unscrew the whole back plate. Some versions need a specialist tool to unscrew them.
Screw on plates use four tiny screws to hold the back plate down. These are more commonly used on 'Sports' or digital watches.
Need to change battery in EH23sa
The battery is actually accessed from the front of the watch.
You should have a "Case Knife" to remove the front bezel.
Remove the band first.
Set the watch in its side. Set the case knife at the groove where the watch band holder meets the front bezel, and give the back of the knife a sharp rap with a small hammer. The front bezel should pop off.
Some watches have a small circular plastic piece that will also come out. Gently remove the movement from the front. The battery (CR 2025) can then be removed from the back of the movement using a small, thin blade. Install the new battery. The inside back of the case should have restart instructions. (Push A -left button once. then push and hold A until hands move to 12:00. Push B once to start reception.
The back of the watch is plastic. Don't try to remove it.
Gently re-assemble movemengt. A watch case press tool is best for finishing assembly. I would suggest taking the watch to a jeweler if you are uncomfortable taking this watch apart. Good luck
Mar 21, 2011 • Watches
How do I remove the back to a Steinhauser Dunn Horizon watch. I need to change the battery.
Your watch has a press down caseback, you need to get a knife or watch caseback knife and look for the depression ot notch on the edge of the caseback, slide your knife up tight to the notch and pop the knife edge up like a lever, the caseback should pop off.
How to change battery on a ladies classic 18 k and steel watch with solid back
Welcome to Fixya,
Hi hope this steps will helped you in changing the battery but I just want you to remind that you have to be careful in changing the battery because it might affect the other part.
1- remove the crown by pulling away from the watch, use your thumb and index fingernail and pull , it will come out
2- remove all 5 gold bezel screws
3 - be careful,, the bezel/crystal will pry off easy
4 - be careful and remove the entire face/hands/watch guts all in one easy step,, or just turn the watch over and it will fall out
5 - small screwdriver and remove/replace battery
6 - reinstall watch guts/bezel and gold screws
7 - push crown back into watch
Thank you for using Fixya.
10helpful
2answers
How do you change battery on E Howard wrist watch, how does bach come off?
The back does not come off (case is in one piece); it's the bezel -- the metal rim that holds the front glass crystal.
There is a small notch in the rim of the bezel (on mine, this aligned with the 'lower left' lug on the case around 7:00 on the face). Be careful as there is an O-ring to waterproof the watch, and this notch goes right into the groove where that O-ring is located. Use a case knife or similar stiff but fairly thin-edge blade to pop the bezel off (it snaps off). Then gently remove the outer plastic ring, noting carefully how the notches are aligned.
The inner module now can be lifted carefully out - the two 'pushers' will not fall out of the case when you do this. The battery is a 3V lithium CR2025, and you will need a fairly small straight-blade jeweler's or optician's style screwdriver to remove the one screw that holds down the battery bracket - it may be tempting to bend this out of the way to change the battery, but please resist that temptation...
Put the module back in the base, put the ring back over the dial plate, and carefully snap the bezel back in place with its notch aligned as you found it. You might want to check and/or lubricate the O-ring as you do this.
Instructions for initializing the movement are printed inside the case: they list the switch for the 'recessed' button as A, and the pusher as B. In case you didn't note them before closing the case: to reset:
1) push A once. (Display will read "SET"
2) Push A until hands are exactly on 12:00 (and display reads "12"
3) Push B once to start reception
You then follow the standard procedure of putting the watch in a window facing Fort Collins, Colorado, until it picks up the time signal and synchronizes itself.
If you need more assistance with the physical module, there is contact information on it from its manufacturer:
[email protected]
Model number on my module is AR600 WWVB (37.5mm)
I have found a fossil watch model BG-2103. I cannot get the back off to change the battery, can you tell me how to get the back off and how much this watch cost.
mcdevito75 here, Look for any Notch in the cover that match a notch in the case, use a knife with a sharp blade and place the knife in the notch and with a slight twisting motion the cover should pop off. Depending on the age of the watch and the functions cost could be anywhere betwwen $25.00----$60.00 Fossil watches are also collectables.
2answers
How do I open the case? The rear bezel has six notches along the rim. I need to regulate the mechanism, which runs a little fast.
You need a special tool to remove the back. I afraid it can only be done by a watch repairer if you wish to avoid damaging the case.
Jan 18, 2010 • Watches
2helpful
I have a Caravelle Bulova watch #48G33 and I need to change the battery. I took it to a jeweler and he mess up the back and told me he did not have a battery that fit. I think he was unable to get the back...
Hey there !
if the back has a notch on the top left of the cover (right underneath to what would be 10'oclock position), it is a 'Pop-up'. But if the watch has 6-8 notches on the back plate of the watch its a screw-off.
Its really hard to say what battery size it would take due to the fact that each watch has a different operating mechanism and its hard to determine that from the model number.
Can't get the back off the watch to change the battery. No indentation to suggest where to open. What do I use to open the watch--how do I go about doing it?
Take your watch to a dealer in that brand. I'm guessing that your watch has square notches around the underside. The dealer has a special tool that will fit into these notches and the back will twist off as it is threaded onto the watch, not pressure fitted into it.
Top The Watches Experts
vince
NOEL
NOEL
Paul Carew
Are you a The Watch Expert? Answer questions, earn points and help others
