You better check if the power supply have complete output voltage.The power supply have 5vdc for the logic and tuner board,12-16vdc to sound amplifier, and 24vdc to back lights inverter.So if there is no 12vdc supply in the power supply,there is no sound in your TV.So check first the supply output of the power supply.Thanks..
Reset instructions from the Sharp Instruction Manual include removing the batteries, re-installing them, then pressing the [OFF], [ON], [2nd F], and [CL] keys in that order. This will erase any saved formulas and data.
The canon pixma mp 210 uses PG-30, CL-31, PG-40, CL-41
It will not recognized the PG-50 & CL- 51
See if you can return it and exchange it for the PG-40 & CL-41.
If not, the only other way is to transfer the ink into the other ink cartridges.
The cartridge cap can be removed by a sharp tap at the back end of the cover.
You can glue back the cover.
If there is an E 1,6 Error code, Ink has run out after you install your ink cartridges
Press and hold the stop/reset button for about 10 seconds to clear the error code.
