SOURCE: Fault with Hotpoint BCI45 Dishwasher
This a generic problem with hotpoint dishwashers..
Water is present in the flood catching tray at the bottom which usually
indicates that there is a leak somewhere. More often than not this is
just a pipe with a poor fitting and simply tightening the clip is
enough to stop the leak. Our machine had a very slow leak from one pipe
(not enough to trigger the alarm) which was fixed in this way. The leak
is detected by a small float switch located in the flood catch tray.
Undo 4 screws on the metal plate under the dishwasher 3 at the front 1
at the back, this reveals The pump check the seals are in place on the
waste pump.
SOURCE: hotpoint dc26 problem
Sounds like a solenoid is stuck, but you have to use a voltmeter to troubleshoot the problem. You can find the schematic inside the door panel; the schematic will show you the drain solenoid.
SOURCE: My hotpoint aqarius dc26 dishwasher has stopped
this may be caused by a leak your dishwasher as a build in anti flood switch which stops water from entering when it leaks into the base of dishwasher . You may be able to check this for yourself by unplugging your dishwasher and slowly pulling it out and lean it back if water runs on to your floor you have had a leak .if at this point you turn it back on it might start to fill again .if it does start to fill turn it off again . it will need further examination to see why it leaking .if you feel you can't do this call your local engineer .
SOURCE: INSTRUCTION MANUAL FOR AN ACER SLIMLINE AP1000-UD400
Download the user manual found in the Acer Support site.
http://us.acer.com/acer/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3750&sp=page15e&ctx2.c2att1=25&miu10ekcond13.attN2B2F2EEF=3750&CountryISOCtxParam=US&ctx1g.c2att92=450&ctx1.att21k=1&CRC=23934287
Select Desktop>AcerPower>AcerPower 1000.
Then in the Selection Tab, click Document. Then you'll find the User Manual.
Hope this help.
Mel
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
