SOURCE: Toshiba 1360 C7 Error Code
TOSHIBA
1310
C7
Fusing unit warm-up error, defective thermistor, fusing lamp or thermofuse
The codes are good for several models.
SOURCE: Error code U2 on a AR201 copier
To find out the sub code for the U2 error hold down the Start key. Below is a list of the errors:
U2-04 EEPROM serial communication error
U2-11 Counter check sum error
U2-12 Adjustment value check sum error (EEPROM)
U2-40 CRUM communication error
To clear the U2-40 error try pulling out the toner cartridge and firmly reinstalling it. If that doesn't work you must install a new toner cartridge. There is a CRUM chip on the cartridge that keeps up with how many impressions have been made with that cardridge. You cannot "refill" these cartridges without replacing the CRUM. This problem occurs frequently with remanufactured cartridges.
To clear other U2 errors you must enter simulation mode.
Perform the following procedure to enter the simulation mode.
Clear key - Interrupt key - "0" key - Interrupt key - 16 - Start key - Start key. The unit should reset.
SOURCE: what is error code f105 for an toshiba e-studio 520 copier?
Dear sir; There have your solution, try to turn power off and on, if can not reset , you have to replace HARD DRIVE, f105 is hard drive problem. good luck! if you need more help please let me know, HAVE A HAPPY HOLIDAY !!!
Hello sir; This error code it can be reset folloe the instruction;
1, press "clear", "interupt", " 0 ", "interupt"
2, enter 16 then press start.
SOURCE: Ricoh 1232c copier error code sc 517
The error is about the fusing unit for to reset the code you must enter into the service menu and reset the SC code 517
For to enter the service menu you should do the follow steps :
1.Enter the service menu by pressing the follow keys in order: yellow key[clear modes] then press "107" number one after other and then press and hold the red key [clear/stop]
2.Hold it down until service mode do not appear if not appear after 10 seconds try again.
After you will be in service mode press the follow numbers :5810 and then will apear on the screen "SC reset" set the value from "0" to "1".
Then turn off and after 5 seconds turn it on the machine.
Please replay if this do not help and write the SC code good because i cannot find the code SC517
