Computers & Internet Logo
m
markku tervola Posted on Feb 28, 2019
Does LG Flatron L1950B-SF work with Windows 95
Layllah Therion
Level 1:
Habit-Forming:
New Friend:
  • Contributor 27 Answers
  • Posted on Feb 28, 2019
Layllah Therion
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
27
Questions
0
Helped
25773
Points
59
Do you have drivers for Win 95 for your device? It should work as a basic monitor. Remember Win 95 driver catalog is very small compared to Win 10. Some monitors on Win 95 needed drivers. Dells did, gateway, etc',
5 Related Answers
Anonymous
  • 21 Answers
  • Posted on Mar 17, 2009
SOURCE: I'm loooking for driver for LG Flatron L194 WT-SF.
log on to the below mentioned link and u will get thedriver for ur monitor
http://wareseeker.com/free-lg-l194wt-sf/
Good luck.
jairo sanchez
  • 276 Answers
  • Posted on Aug 21, 2009
SOURCE: my screen keeps going blank after about 2 hours
check the flexible connectors conecciom tambein There is a false contact
Anonymous
  • 540 Answers
  • Posted on Mar 05, 2010
SOURCE: i need window 7 driver for a lg flatron monitor
There is no need to install any driver for the monitor as the inbuilt drivers always work with all operating systems and windows 7 have thousands of drivers inbuilt.
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Apr 16, 2010
SOURCE: LG FLATRON L1953T-SF 17
Did you inspect the caps, any bulging one? Measure the power supply to see if you do have 5v and 12v on the power supply/inverter board.
See pictures and websites so you will know what to look for:
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Dimitar Todorov
  • 241 Answers
  • Posted on Aug 05, 2010
SOURCE: I have an LG Flatron
If you are using analog VGA cable, replace it with one that has ferrite rings near both ends. The best is to use DVI digital cable but this depends on the capabilities of the videocard and the monitor ofcource, but I think this monitor has DVI input.
Cant display images just blinking
is the power light good.
is the OSD working?
Lg logo appears then goes in to power saving mode LG Flatron Wide Monitor
Hello davidhague99 ,
Check your VGA cable if connected properly to your CPU or Video Accelerator Card,if connected properly,try another VGA cable and if the problem persist you need to try another source.
hope it helps thanks
6helpful
2answers
LG Flatron L193ST. Relatively old model. The monitor screen stays dark upon connecting with a power socket and the power LED blinks rapidly in a yellowish amber colour. A quiet pulsating sound emits from...
L193ST common problem!! solution is only by replacing 2 capacitors 470uf 25v located on the power supply pcb inside the lcd they are neer the long cable connector
remove the 8 screws from the lcd back panel including the holder screws,
use a thin metal stick like a knife and insert it between the back pannel and the front black panel but slowly remove the black panel not to scratch it
remove the metal protection panel 4 screws
the power pcb becomes visible
remove all connected plugs and the 3 screws
desolder the 2 capacitors and replace them
assemble back your lcd and enjoy
30min time of work 5$ cost
1helpful
I need window 7 driver for a lg flatron monitor L226WTQ-SF Cheers
2helpful
Can't get picture to fill screen on a W2242OP LG Flatron
Downloaded manual from LG website and followed instructions to reset monitor.
My screen keeps going blank after about 2 hours
1helpful
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
