SOURCE: HDMI Malfunction
You may have to activate that imput through your menu.Alot of plasmas have the ability to mute imputs.
SOURCE: I cannot get a signal on my Phillips 50
if you haven't unplugged the unit for 30 seconds, try that. otherwise, if that doesn't help, probably a board needs to be replaced. call phillips for service.
SOURCE: new home theater setup- no signal at tv using onkyo tx=sr605
This might somewhat help. Today I went back .. I went HDMI out of the Cable box and DVD player into 2 of the TVs HDMI ins. The digital audio out from each, straight to the receiver and things are working ok. All speakers are working OK. Sound isnt as loud or crisp but unfortunately I found no other solution.
SOURCE: XBox 360 to Reciever to TV via HDMI no sound
I recently got the same receiver and had the same problem. Here's what I was told - and it worked for me:
Even though HDMI cables carry audio and video, for whatever reason this reciever won't accept audio through hdmi. Apparently only much more expensive recievers carry audio through hdmi. What you have to do is run optical audio cables from your xbox, cable box, dvd player or other video device to the optical inputs on the back of the reciver. Then you customize the scene buttons to match your video and audio inputs.
You can get these optical cables pretty cheap on line or even at target. Don't get ripped off by Best Buy for these cables. I love best buy, but they rip off on cables!
This receiver is great - once I got it all figured out and running right I've loved it! Hope everything works out for you!
SOURCE: Philips TV HDMI CEC EasyLink tries to control Cable set top box
I finally found a fix to this! YAY. I thought I might have to return the TV. I have the Phillips 42PFL5603D, but should work for other models.
On the TV press menu
picture settings---picture---dynamic contrast (turn off) AND active control, turn off
If you have Comcast Moto box:
on the Cable box go menu--->setup--->cablebox set up---RF BYbass set to ON
If you have a non-Comcast Moto Box, I'm sure there is an RF bypass setting in the menu. You'll just have to look for it. Another fix was close saying to only turn of the active control, but it took all 3 of these for it to work consistently. The latter let it work for all of 30 seconds.
