Televison & Video Logo
Davy Kangwa Posted on Feb 28, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What are the 2 values of diodes in a Philips TV 21pt2110/79r please help me
KISHORE DESHPANDE
Level 2:
Sniper:
  • Expert 64 Answers
  • Posted on Mar 01, 2019
KISHORE DESHPANDE
Expert
Level 2:
Sniper:
Answers
64
Questions
0
Helped
27132
Points
167
3 Related Answers
tedatcit
Theo Nikolaidis
  • 93 Answers
  • Posted on Nov 06, 2010
SOURCE: please let me know the
read the diode. It will tell you the value on body.
polytek
  • 453 Answers
  • Posted on Nov 12, 2010
SOURCE: The problem is power out
hi;
  1. Diode: UF4007, 1000V 1Ampere ; for 72V
  2. Diode: GUR460L, 600V, 4Ampere : for 50V
  3. Diode: UF5404,400V, 3Ampere: for 6.3V
  4. Diode: UF1G, 400V, 1.2Ampere: for 13V
  5. Diode: TVR10G, 400V, 1Ampere: for -12V
Anonymous
  • Posted on May 25, 2011
SOURCE: philips 42pf9630a/37 part value at
PHILIPS WILL NOT HELPYOU WITH YOUR TV. THEY HAVE A CLASS ACTION LAWSUIT AGAINST THEM FOR THE TVS GOING OUT. CHECK IT OUT.
2answers
My Philips LCD 55PFL5706?F7 got wet and I cann't turn on, how ca I fixed it?
Contact the authorized service center for Philips. Never switch On this TV; until it have been checked by the experts at Philips.
Electro help
3helpful
3answers
Fuse keeps blowing in my philips 32pfl3505d/f7 tv
Good day!!!!
That problem is cause of shorted bridge diode or power mosfet..
just see the picture below to see the image of bridge diode and power mosfet..
If you don't have a tools or you have no electronic background you only have to is order the new power supply board..
I hope this solution will be helpful..Thanks for using fixya....
Philips 42pf9630a/37 part value at d8010,d8011,d8025 burnt diodes, cap8057 bulged,need to replace these diodes & where can i buy them
I want to know the value of transistors. my Philips TV 25PT4473/69T power supply is blown up. If Circuit diagram could I get
You have to try in Google search.
If the transistor body is not damaged, you can read the type no. Replace it with identical No. Make sure the diodes and capacitors are not damaged. Check with multi- meter
10helpful
3answers
UNKNOWN VALUE OF VOLTAGE ZENER DIODES
I was not able to find any service or schematic for this model. The colors means that the value is 22.6 volts zener diode with the other blue band indicating where the cathode is.
Could you tell me where or what other components this zener diode is connected to?
Power disconnectd when i switch on my TV
maybe the power regulator is damage or there some zener diode change value
2answers
TV SHUTS OFF BY ITSELF
there is a infra red emmiting diode inside that has failed. this is the diode just under the prism inside the unit. replace that and re-time the mode switch. the unit is not made by philips but by funai so no support can be given to you from philips. I've repaired close to 60 of these with the same problem you have.
1helpful
2answers
Tv shuts off and won't turn on
sound like vertical section problem, need to replace back same same # vertical ic& importance thing need to check component around ic like capacitors & resistors.then the vertical section be working fine. good luck!
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
