Question about Dewalt Tools & Hardware - Others
My dewalt 431 belt sander jammed with a towel. i removed towel but could not restart. is there any way to reset?
    Top Expert:
  • Dewalt Master
  • 29,164 Answers
No, but there may be an overload fuse. My guess is that it is part 62 here, but not available. Take it to a DeWalt service centre
https://www.ereplacementparts.com/dewalt-dw431-type-electric-belt-sander-parts-c-1009_2742_2764.html
It is available here, but is $88. Lot of money to lay out on a guess, which is all the more reason to get it looked at professionally. It may also be the motor windings burned out.
https://www.toolpartsdirect.com/dewalt-dw431-type-5-electric-belt-sander.html
Posted on Feb 27, 2019
SOURCE:
  • 302 Answers
SOURCE: how to remove the stick on paper??
grab a corner of the paper and peel it off
Posted on Nov 04, 2009
Testimonial: "thanx"
SOURCE: I have a Canadian tire model 55-3550-2 belt/disc
I went to a bearing/powertransmission supplier. The number on the belt was all they needed. Picked up a new belt for $6.50.
Posted on Nov 28, 2009
seanpwright
  • 2030 Answers
SOURCE: Dewalt DW433 belt sander stop working, why?
Check the brushes for the motor they may have gone bad or broken, I have seen this happen before on dewalt tools.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on Apr 02, 2010
rowdy45176
  • 2176 Answers
SOURCE: the sanding belt has broken and jammed in behind
UNPLUG tool and with a pair of needle nose plliers and patience pull the belt loose it might take some time but that isabout the only way to do it.
Posted on Oct 23, 2010
radar001
  • 1051 Answers
SOURCE: I just used my DeWalt
You can probably get an owners manual at www.retrevo.com It's a free site but requires registration (also free).
Posted on Oct 31, 2010
Dewalt belt sander stops sanding when pressure applied
I would suggest giving our Service Center so we can get your unit looked at. DEWALT com
Mar 15, 2015 | Dewalt Tools & Hardware - Others
Towel caught in front roller
Well, it sounds like you have a belt sander. I would start by sacrificing the towel and the belt. Even if you tried all day and were able to save them they would probably look like they got caught in a sander. Get a utility knife and change the blade, you will want a brand new sharp blade for this. Start by cutting as much of the exposed towel off as you can. Remember, at this point the only thing you might be able to save is the sander. Cutting off the belt will relieve the tension. When you cut the belt give yourself enough belt on ether side to get a good grip. You might need to pull the belt back and forth as you remove small pieces of the towel. A good pair of pliers might help grip the towel fragments. When you finally do remove all the towel and the belt, take some time to look around the drum for fibers that might be stuck in the bearings and pull them out. You may need needle knows pliers for this. Keep the towel shreds for sating rags to finish the project you're working on so it will not be a total waist.
Good Luck
Ray
Apr 28, 2014 | Makita Tools & Hardware - Others
I accidently ran over the cord with my DW430R 5.2 Amp belt sander and it's wedged so tightly between the wheel and sander body and I can't get it out.
If you release the belt that would give you more room to get the cord out. When you releas the belt it brings the rollers together which loosens the belt.
Mar 13, 2011 | Dewalt Tools & Hardware - Others
I have a Black and Decker Sander, model # 5.2 A and I cannot find a motor belt for it. The belt that broke has "made in China" stamped on it and the numbers 110XL 031 stamped on it.
You might try Dewalt. I have a Black & Decker weed eater that had a broken belt and I had to order it from Dewalt. I was told that they had some kind of merger. Ordered it and it worked just fine.
Mar 01, 2011 | Black & Decker BR300 3''x18'' Belt Sander
I have a Porter Cable Model 371 2.5" X 14" Belt Sander. I broke a belt, when I did it jammed and also broke a rubber sleeve that covers the Drive Wheel. I have yet to find this rubber sleeve in any part...
Unfortunatly that sleeve is not available, you will need to purchase a whole new drive wheel. The Drive wheel is $9.66 from DeWalt Service Net. Porter Cable, Delta & DeWalt are all owned by Stanley Black & Decker, you can contact DeWalt Factory Service for all parts. 1-800-4-DeWalt You can order the parts on-line, over the phone or though a local service center. The website is www.dewaltservicenet.com Below is the parts diagram for your sander. The part number for the drive wheel is A16439
http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=65594&typeId=15450&documentId=34604
Oct 10, 2010 | Porter Cable 371K Factory Reconditioned...
Dewalt DW433 belt sander stop working, why? While sanding shutters, my sander just stopped. Any fixes?
Apr 02, 2010 | Dewalt DW433KT Heavy Duty 8 Amp 3 Inch By...
Size of hole in 10inch blade for dewalt power workshop radial arm saw
The size of the hole directlly relates to the size of the blade that fits on the saw, do not change blade sizes it is dangerous and will not fit properly
Mar 10, 2009 | Dewalt Factory-Reconditioned DeWalt DW432R...
Motor runs but the drive drum that hold the sanding belt does not turn.
Instead of removing the drum, remove the belt and the cover over the gearbox. The gearbox cover is normaly fixed in place by screws around the drive pulley. There may be a couple of screws under the pulley, if so they can be accessed via holes in the pulley wheel itself. Check for worn or stripped gears. These gears can be replaced if need be, but if this is the case make sure you remove and clean out all the grease first and replace that aswell as it may contain bits of teeth that have come off the faulty gear. As far as I know belt sander drive rollers can not be removed without removing the drive inside the gearbox first.
Oct 27, 2008 | Dewalt Factory-Reconditioned DeWalt DW432R...
Tools & Hardware - Others Logo
Top Dewalt Tools & Hardware - Others Experts
John Trevino
Ruben Bustamante
john h
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
