Model. KX-TGF370
Press the [?] or the [?] button to select "Block a single number" or "Block range of numbers", press "SELECT" Press [MENU] Press the [?] or the [?] button to select "Erase All", press "SELECT http://www.fixya.com/support/t26936453-clear_blocked_call_list_kx_tgf370
SOURCE: Block international call
In the manual, there's a section on Toll Restriction (TRS). It's not something that is easily explained in a public or any forum.
I did attempt it once, and this happens to apply to a TA-824 which you may or may not have. Anyway, here's a link to that forum and thread http://members4.boardhost.com/ablecomm/msg/1201934621.html
Carl
SOURCE: how do you clear the display (missed calls)
Finally figure this out after days of searching. You have to use the menu to navigate to "View Caller ID" and go through all the missed calls or press Clear (Mute) to just erase them.
SOURCE: how to block "0" for
As was pointed out to me, you could take a screwdriver and pry the 0 key off the tone pads :-)
Panasonic systems restrict calls by tables called Toll Restriction (TRS). It's a complete section in the installation and programming manual. It involves setting tables, usually in the 302-306 area, then picking a class of service for the phone that acts on the numbers dialed.
In the simplest systems, the TA series, you have 20 restrictions per class 2-5 and one 80 entry exception table. It's a little tricky to set up in that a COS-2 extension has all the restrictions in COS-2 tables, but a COS-5 extension has all the restrictions in COS-2,3,4, and 5 :-)
Your Pana installer can do this fairly quickly, but if you plan on doing it yourself, please read the TRS examples carefully.
Carl
SOURCE: I can not remove call block from my phone. model
I had a similar problem with a KX-TG6445. To edit the call block list from the handset press Menu then # 2 1 7. This will take you to the call block menu where you can edit or erase the blocked numbers list.
SOURCE: how to block outgoing call via PBX panasonic KX-TD1232 DBX
You have this
posted in the wrong product category. Please select another category
appropriate to the problem.
