How to Unlock your BLU Zoey Phone. here is the brief solution
https://mobile2mobile.net/phone-unlocking/blu-unlocking/zoey/
You can also get the network unlock code for to use any network SIM
https://www.unlockninja.com
SOURCE: Forgot password
Good Day,
Have you tried the default code?
By default the code is the last four digits of the phone number assigned to the phone. However if the code was changed there is no way to retrive it other than taking it to a tech and having the firmware reset.
Good Luck
Hope this helps
SOURCE: Cant unlock phone
Go to the at&t site and get the manual...if you don't have it. It should tell you about the password reset feature.
SOURCE: how do you unlock a log in password if you don
Do you mean windows login password? If you forgot windows password, you could create a windows password reset disk on an available computer which could download from Internet. With the disk you could remove the forgotten password. Only four steps:
Step 1: Download Windows Login Recovery from http://www.windowsloginrecovery.com and install it on the available computer
Step 2: Run the software and use it to burn a Windows password recovery disk (you could burn the file into the blank CD/DVD or USB flash drive)
Step 3: Change the BIOS setting of your locked computer to make it boot from the CD-ROM (Start computer and press F2 or Delete to enter BISO setup)
Step 4: Boot your locked computer from the created disk and remove the Windows password
It is easy and safe. Hope to help you.
SOURCE: Hi, I have a samsung sgh-A197
Well if you are tied to a particular network all you have to do is to unlock your phone to use it any other GSM network. You can get the unlock code through online. Give your IMEI number & get the unlock code for ur mobile .............You also get through online..........I will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
