1. Press and hold the "+" or "-" button to enter the alarm settings.
2. Press the "+" or "-" button to choose the desired hour for the alarm.
3. Press the SET/RESET button to confirm and move to the minutes setting.
4. Press the "+" or "-" button to choose the desired minutes for the alarm.
5. Press the SET/RESET button to confirm and move to the alarm mode setting.
6. Press the "+" or "-" button to choose the desired alarm mode (i.e. one time, daily, or weekdays).
7. Press the SET/RESET button to confirm and activate the alarm. The ALARM indicator light will turn on when the alarm is active.
8. To turn off the alarm, press the SET/RESET button. The ALARM indicator light will turn off when the alarm is deactivated.
On the radio, repeatedly press the Alarm Mode button until the desired alarm mode indicator below "Alarm" is displayed. The music note indicates radio and the sound waves indicate the alarm tone. If no icons appear on the display, that means the alarm is turned off
Radio and tone
Radio only
Tone only
Alarm off
To turn alarm 2 on/off, follow these steps:
Turn the system off
On the radio, press and hold the Alarm Set button. "Alarm" flashes on the display
While holding Alarm Set, press the Alarm Mode button once. "Alarm 2" flashes on the display
Release Alarm Set, and repeatedly press Alarm Mode until the desired alarm mode indicator above "Alarm 2" is displayed. If no icons appear on the display, that means the alarm is turned off. The "Alarm 2" indicator will continue to flash on the display for 10 seconds. When the flashing stops, alarm 2 is set
To turn off the alarm I pressed the alarm set button. While in the alarm set mode press the up button to turn the alarm and snooze off and on. That's what worked for us. Neat clock, the instructions are just a little lacking:)
this is a factory alarm, the problem is the alarm is active, you will need to use the door locks to turn alarm off, insert key in driversdoor and lock and then unlock door this will turn alarm off, if that doesnt work then use pass/side door, the lock has a built in switch that knows when the door is locked or opened, the driversdoor may have a bad switch so inturn the computer thinks the door was forced opened without key and it is turning alarm on, so again use the key to unlock door try the pass/side if driversdoor doesnt work. good day
To turn off the alarms follow these steps -
After the alarm sounds, press the "F" alarm off/reset button to shut the alarm off but retain the 7-5-2 alarm settings.
If you want to turn the alarms completely off and cancel the 7-5-2 settings, press the "alarm" button so that the "alarm" indicator is no longer visible. As long as you can see the word "alarm" on the display the alarms will continue to go off according to your 7-5-2 alarm settings.
I'm afraid I don't have a manual, but I could walk you through the steps...
1. Press the clock/sleep/timer button twice.
2. Press enter button.
3. Turn dial to set hour for alarm to start.
4. Press enter button.
5. Turn dial to set minute for alarm to start.
6. Press enter button.
7. Turn dial to set hour for alarm auto-shut off.
8. Press enter button.
9. Turn dial to set minute for alarm auto-shut off.
10. Press enter button.
11. Turn dial to select either Radio or CD alarm setting.
12. Press enter button.
13. Turn dial to adjust volume of alarm.
14. Press enter button.
15. Press standby button. Alarm is set.
I hope this helps! Best of luck finding a manual if you still need one. :)
Here are the instructions to view, change alarm time and turn off alarm:
From normal time display:
Press MODE once to display stop watch. Press MODE again to change alarm time. Press MODE again to change time.
Press RESET once to display current alarm time. Press and holdRESET then press START to turn on and off alarm (watch for alarm symbol on top left) Press and holdRESET then press MODE to turn on daily alarm vs one time (watch day marker lines at the bottom)
Hope this helps.
using the button at bottom left of watch, set to the alarm mode and press the button at bottom right to toggle between alarm settings. The bell and wave symbols will appear and disappear on top left of watch display.
