Question about Video Game Consoles & Games
Dobry den jak na instaluji memory card slot 1 ps2 do pc?
    Top Expert:
  • Video Game C... Master
  • 64,234 Answers
USE ENGLISH
Posted on Feb 27, 2019
SOURCE:
  • 18 Answers
SOURCE: PS2 doesn't acknowledge memory card in memory card slot 1
make sure that theres nothing blocking the mem slot 1.
Posted on Jan 02, 2008
  • 4 Answers
SOURCE: PS2 Memory card problem
there is an eternal problem get a NEW ps2
Posted on Aug 31, 2008
  • 116 Answers
SOURCE: PS2 memory not working on gutiar hero
If it is guitar hero 2 its a known isssue that corrupts the load file, are memory cards madcatz?
Posted on Dec 11, 2008
  • 86 Answers
SOURCE: Memory Card Corrupted
These cards have become so cheap it would be better just to buy a new one and use that as backup for the non corrupt data.
Posted on Apr 01, 2009
  • 43 Answers
SOURCE: My memory card slot 1(PS2) does not read cards but slot 2 does?
take out slot one memory card and insert your second memory card into it (they are supposed to use slot 1)
Posted on Jan 04, 2010
Dobry den kde bych nasel ovladac na Reekin Webcam moc dekuji
http://www.drivermax.com/driver/update/Imaging-Devices/Sonix/Reekin-Webcam--2/1430360
Feb 21, 2015 | Computers & Internet
I have no manual my problem is I have a First Generaiton Ps3 and would like to transfer my Ps2 memory card and cant figure it out. pleae help thank you Nichole
Prerequisites There is no PS2 memory card slot in the PS3 so will need a Memory Card Adaptor. Sony made an official adapter but there are also a number of cheaper alternatives. Buy one online:
Steps
  1. Plug your PS2 memory card into the adaptor
  2. Plug the adaptor into a free USB port on your PS3
  3. Go to the "Game" menu in the XMB and choose "Memory Card Utility (PS/PS2)"
  4. If the adaptor is working you should see an item called "Memory Card (PS2)". Below the title should be the size of the card and how much is in use-in my case "1334 KB / 7998 KB"
  5. Press the controller's Triange button to get the Memory Card options. Select "Copy"
  6. Select "Yes" to confirm the copy from memory card to the hard drive
  7. Enter a name for the new Internal Memory Card that will be created on the hard drive, or leave the default name. I named mine "Original PS2 saves". Select "OK"
  8. The data will be copied. If the amount of saved data is too large, the system will automatically create multiple internal memory cards
  9. You may be informed that the new internal card has been assigned to a "slot". These slots are an emulation of the physical memory card slots in the PS2, so similarly you may only have two internal/virtual cards "plugged in" (assigned) at a time. The internal memory card must be assigned to slot 1 or 2 to be available when you run PS2 games
  10. The new internal memory card should now be showing in the XMB, under Game > Memory Card Utility
  11. Selecting the card will allow you to browse the game saves that were copied across!
Jan 04, 2011 | Video Game Consoles & Games
Dec 23, 2009 | Sony PlayStation 2 (PS2) Console
My playstation keeps saying to put in a memory card.. even though I have done
did you try reading the memory card without any game discs put in via the ps2 menu?
is your memory card working properly? could be a corrupted memory card or a faulty memory card slot.
try putting a friend's memory card on that same slot.
if it works... then your memory card is gone bad...
if it doesnt work...then your memory card slot has gone bad.
else try putting your memory card in your friend's ps2, see if that ps2 reads your memory card. if it does...then your memory card slot has gone bad.
Sep 07, 2009 | Sony PlayStation 2 (PS2) Console
My ps2 will not reconize my memory card it says no memory card in slot 1
try blowing into the card and the slot of ur ps2. clean them out
Jun 22, 2009 | Sony PlayStation 2 (PS2) Console
Joey64,. pno ko nman mla2man kung ang anu clock speed ng pc ko? tska kung anu compatible na memory and videocard. P3 733 is my pc.
733 is the processor. thats determining the speed of your system. compatible memory is SDRAM 256 mb, AGP video card geforce 1-4.
sana ok na sayo.
bakit di ka mag upgrade ng PC. marami namang mura dyan 16T ok na.
Jan 10, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
My memory card slot 1 doesn't work can I change the unit so that games will save to slot 2 instead or how do I swap the slots in the unit
When you choose to save when you are in any game, on the save screen you can choose to save to slot 2 provided there is a memory card inserted in slot 2.
Dec 27, 2007 | Sony PlayStation 2 (PS2) Console
Dec 26, 2007 | Sony PlayStation 2 (PS2) Console
Ps2 memory card
Hi Lofatman,
If this problem happens with the memory card when its in either slot 1 or slot 2
I suggest you clean the contacts of the memory card.
If it just happens when you have in Slot 1 or Slot 2 only,
 Go to Radio Shack and get a Can of contact cleaner that has a Brush built into the Spray nozzle.
  1. Turn off the PS2 and disconnect the power cord.
  2. Use a small screwdriver to press open the memory card slot. Do not use too much force, its delicate.
  3. Push the Brush sprayer up into the memorycard slot and spray a little and brush away at the memory slot contacts.
if you do not have success with that, you must open the PS2 case, and Remove the Controler ports and clean up the whole controller port assembly.
If that doesn't work, and your frustrated and not Electronically skilled enough to do this.  I can get the PS2 in tip top shape, for $32 and that includes return shipping.  I run the website www.playstationclinic.com
This should put you in business.
Oct 17, 2007 | Sony PlayStation 2 (PS2) Console
Video Game Consoles & Games Logo
43 people viewed this question
Top Video Game Consoles & Games Experts
Ekse
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
