Will the dial at the back turn the hands backwards? if it does set the clock at 12 o'clock then turn back to eleven . wait a minute or so then set back to twelve. if this changes the dings keep doing this till it is properly set. Not sure if this will work for your clock as mine is a different make. Try it once and see if it works. If it does not change do not keep playing with it.
SOURCE: dont know how to turn on hourly chime timex atlantis 100
Set chime and Alarm on or off
Press MODE to select ALARM
Press START/SPLIT to change (clock sign and chime sign will appear and disappear as you keep on pressing).
Press MODE again and you are all set.
SOURCE: Resetting stopwatch dials - Armani AR5331
When you reset the big seconds hand to zero, the hour and the minute hand are not engaged in this function, so, there is no fault with the watch movement.
Do as follows:
1) pull out crown and set the hour and minute hands at 6 o'clock (they must be lined perfectly in opposite directions)
2) push the crown in half way back (not completely)
3) push and hold the button at 2 o'clock (set the big seconds hand to zero) and release it when done
4) when big seconds hand is zeroed push the crown back in
5) pull the crown out again and set desired time
6) push the crown back in.
If all actions described do not work, you will have to visit your nearest watch repair shop and ask to refit chronograph hand as in this case it is out of balance (not pointed at exact mark).
Rate me, please.
SOURCE: athletic works watch owners manual
if you press both buttons on the right at the same time it might work. Im not sure if it will for ur model, but it worked for mine =)
Pull the crown to first position (where you set the date) then adjust the dials with buttons.
uhrmacher
SOURCE: Same problem, I cannot shut off hourly chime. Men's model CG111M
On the CG 111M, the chime is turned off and on by pressing the start and reset buttons at the same time. Those two buttons are on the right side of the watch face.
