SOURCE: JBL Eon 15 Blown Fuse
These fuses are most likely 3 Amp fuses. Please note that if the replacements blow as well, that there is a problem within the amp section that will require repair.
Dan
SOURCE: I have a jbl eon g2 and used it at 1pm and then at
There is nan internal fuse right behind the board were you plug the power cable in. You have to split the cabinet to replace.
SOURCE: what is is the output IC no for the high driver of jbl eon
Download service manual here:
http://www.free-service-manuals.com/JBL_EON15-G2_Service_Manual_L38587/
SOURCE: I have the JBL Eon 515 Speakers.. I found a blown
did you get the problem fixed because iam having a similar problem i have a eon 515 that would not power on
SOURCE: My JBL eon 15g2 speaker was working fine and then
the braided wires from the speaker connectors to the voice coil could be broken (from repetitive movement) or it could be the voice coil it self that could be cut open from a miss alignment of the cone (ware and tear), delicately push on the cone and feel if it rubs, a simple test is to check the IMPEDANCE of the speaker with a OHMMETER, if you have a reading (4,6,or 8 ohms) than the speaker is fine, check the rest of the wiring, if it reads OPEN than you need a new speaker...
you want JBL Professional group if this involves the Eon product line.
1-800-852-5776
Or on the website
