Page 7 of the manual refers. The grind change will only work if you change it with the machine running and will take a while for the grind change to appear in the dispensed coffee. The quantity of ground coffee can be adjusted, and so can the amount of water mixed with the coffee and dispensed to the cup.
I've long ago lost the manual that came with my grinder (I actually don't remember if it even had one), but I don't think it listed grinding times. You just grind a few seconds and check, then grind a little more if it's still too coarse. Unlike a burr grinder which is adjustable, in a blade grinder the same grind time may result in different consistencies as you change beans. By now I've just learned how long to hold the button for the different beans I buy, and the first few times I try a new blend or varietal I have to adjust the time. I think you'll just need to experiment and then you'll know what works best for your tastes.
check the timing slots on your left(driver's)side camshaft timing sprocket..compare new sprocket slots to old gear..i bet you have a newer gear on engine now..different timing slot arrangement..your controller will not recognize these slots..they changed in 2002 model year to a different engine controller..you will need sprocket for your model year vehicle..i hope this helps
I, just adjusted the the solis 167; first remove the Bean container by turning counter clockwise and the pull straight up) then remove the timer dialer (time/quantity control), then remove the cover by lifting the locking tabs (2 slots each side) with a flat screw driver. Once you removed the cover. Pull straight up the the white ring with the metal cup. Now you see a dark ring which is clicked on the with unit. When you look under the ring you an see little holes all along the white unit (that's important because you need to mark your old position). After marking the thr ring on the white unit, pull off the the dark ring by slowly pulling the ring outwards just on 2 places on the ring where there an small hole in the ring (there are 4 holes). When you turn the ring you will see 2 nobs, now place back the ring with the nobs 2 places further(clockwise) than the old position. You have just adjusted the grinding control! Place back all parts in reversed order. To place back the Bean container you must be aware that there are 2 black nobs in the machine and 2(different sizes!) on the container, they must be placed in a cross. I trust you will hav succes. Don't turn to far at once because you have now modified the machine and this could damage it! I will assume no responsibillity for damages! Masta NL
Since your WRK54G is already bad, I will advice you to get this WRT54GS router because i can tell you that it work fine and the connection is much faster compare to this WRT54G2 and WRT54GS is pretty much stable compare to the WRT54G2 since I have work for Linksys for almost 3 years...
DOn't forget to rate the solution FIXYA thank you...........
